not showing square
« back to Coffee Lounge forum
Forum topic by Jasper64 posted 07-09-2018 03:18 AM 635 views 0 times favorited 7 replies Add to Favorites Watch
View Jasper64's profile
Jasper64
4 posts in 561 days
07-09-2018 03:18 AM
I am a beginning wood worker with a lot of why can’t I figure this out.
Just purchased a new miter saw and after setting it up and making my first cut, wood shows square while holding on one side and when I check the other side it isn’t showing square. this happens on the miter saw and the table saw. Need help.
-- Brad, Seymour, IN.
7 replies so far
View Woodknack's profile
Woodknack
13008 posts in 2984 days
#1 posted 07-09-2018 03:43 AM
Set them up again or buy a true square.
View Lazyman's profile
Lazyman
4495 posts in 1991 days
#2 posted 07-09-2018 04:33 AM
Are you sure the sides of the board are parallel? If it’s twisted or warped, that can also be a problem.
Jasper64
4 posts in 561 days
#3 posted 07-09-2018 11:09 AM
I will check to see if the sides are parallel. Thanks.
View 000's profile
000
2859 posts in 1503 days
#4 posted 07-09-2018 01:37 PM
- Jasper64
While your at it, check to make sure your square is square also.
View BroncoBrian's profile
BroncoBrian
875 posts in 2563 days
#5 posted 07-09-2018 10:43 PM
Yep, you would be surprised how many big box stores sell squares and levels that are not either square nor level.
Sounds to me like the board needs to be jointed and cut straight lengthwise. Or you see better with one eye?
-- A severed foot is the ultimate stocking stuffer.
Jasper64
4 posts in 561 days
#6 posted 07-10-2018 12:07 AM
I will be jointing said board with a homemade jig, then sawing it again to check for squareness. Just won’t happen tonight. 4:00 a.m. comes early.
Woodknack
#7 posted 07-10-2018 03:30 AM
Yep, if you’re going to invest in reference tools, spend good money.
