installing a incra ls-17 to a unisaw
Forum topic by ruger posted 07-08-2018 03:36 AM 652 views 0 times favorited 3 replies Add to Favorites Watch
View ruger's profile
ruger
136 posts in 707 days
07-08-2018 03:36 AM
hello, I have a bench dog cast router wing mounted on the left side of my unisaw. today I ordered the incra ls 17 fence kit . to use as a router fence. I make a lot of keep sake boxs and urns. all of my dove tail work has been with a porter cable dove tail jig. want to do different joinery other than the standard joints. my question is those who own this fence system how have you mounted it to a unisaw to use a left side mounted router wing? I went to the incra pdf instructions and they have you mount it to a laminated type router table.. can I mount it to my miter t tracks on my table top or am I going to have to mount it on a wood base and align and clamp it to my table top? I guess the best set up would have been order the table saw fence system with rails and all the correct hardware but thats not in my budget and i like my unifence. thanks,
3 replies so far
ruger
#1 posted 07-08-2018 01:02 PM
what I plan on doing is making a sled and attaching it to my miter slots with the ability to snug it down. thanks
View splintergroup's profile
splintergroup
3222 posts in 1834 days
#2 posted 07-08-2018 02:11 PM
My first thought was to do as you intended, mount the Incra mechanism to a board attached to a good fitting miter bar. If you have “T” miter slots, clamping down will be a cinch!
ruger
#3 posted 07-09-2018 08:47 PM
after a little research incra miter sliders are my best bet. on a incra build it panel.. panel is pre drilled for their slider tracks and you can lock them down to take any slop out of tracks. or i can make my own. but going with the incra due to the ability to lock the tracks.
