Covering blotches from sanding stain
Forum topic by FamilyMentors posted 07-05-2018 04:55 PM 355 views 0 times favorited 2 replies Add to Favorites Watch
View FamilyMentors's profile
FamilyMentors
8 posts in 561 days
07-05-2018 04:55 PM
Topic tags/keywords: stain sanding
I’m new here. Thought I’d ask how to get the color consistent without having to sand to the wood. The “blotching” was caused because the veneer was uneven when doing a light sanding to remove stain that dried before taking it all up.
Currently has a coat of wipe on poly over gel stain. I was thinking about trying to restain just the blotchy areas but don’t know how or even if that’s an appropriate method.
2 replies so far
View EarlS's profile
EarlS
3409 posts in 2949 days
#1 posted 07-05-2018 05:19 PM
Generally, a sanding sealer applied before staining or finishing helps with blotching. Since you have a coat of finish on already, you could try re-staining the entire piece.. It will likely darken things up and hide/blend the blotched areas. The one coat of finish will act as a sealer. I’ve used this approach on cherry when I stain it and things get blotchy.
FamilyMentors
8 posts in 561 days
#2 posted 07-05-2018 05:30 PM
Generally, a sanding sealer applied before staining or finishing helps with blotching. Since you have a coat of finish on already, you could try re-staining the entire piece.. It will likely darken things up and hide/blend the blotched areas. The one coat of finish will act as a sealer. I ve used this approach on cherry when I stain it and things get blotchy.
- EarlS
Thanks. Should I do a “between finish coats” light sanding before next coat of stain?
I like the way the grain looks in the non blotchy areas. Is there a technique for feathering in stain only in the areas that were sanded through? Im using Minwax Dark Mahogany gel stain.
