Live edge end table
Forum topic by willhime posted 07-05-2018 04:15 PM 533 views 0 times favorited 2 replies Add to Favorites Watch
View willhime's profile
willhime
146 posts in 2150 days
07-05-2018 04:15 PM
Topic tags/keywords: jig question resource tip trick oak finishing
I’m making a live edge end table or small coffee table and there’s some rot along the main edge. I don’t want to lose it because it provides a decent amount of surface area, and 2, gives the piece more personality. Is there a decent or elegant solution to making the rot edge usable where it won’t start flaking away? I thought about doing a thin epoxy wipe across it, or putting wood hardener into it. The other idea was letting it soak up a bunch of arm r seal till it’s saturated and dried. Is there a decent way to go about this ?
-- Burn your fire for no witness
2 replies so far
View John Smith's profile
John Smith
2135 posts in 773 days
#1 posted 07-05-2018 04:51 PM
another topic for 100 different approaches.
if I were doing it, I would consider these methods:
(1) rout out the underside on both good and bad parts
and put in a duchman with epoxy.
(2) drill some 1/2” dia holes and epoxy in wood dowel rods
if you do use wood dowel rods, cut a groove in the rod to release the pressure
so the excess epoxy can escape: or make the hole bigger or – use 1/4” rebar in the 1/2” holes.
(3) soak the rotten end in CPES penetrating epoxy to restore
the rotted wood & seal it prior to applying your finish of choice.
[and not a thin epoxy “wipe” – the epoxy or hardener must soak in to the core].
(and the same treatment for the end grain).
BTW ~ Lookin Good so far !!!!!!
-- I am a painter. That's what I do. I paint things --
John Smith
#2 posted 07-05-2018 08:31 PM
on the underside of the table,
Excavate the red area 1/2 – 3/4” deep, apply thinned epoxy, let it soak in and harden.
Cut a dutchman the same size with the grain orientation the same.
Epoxy in place. Let cure. sand smooth.
