Box joints on the router table
« back to Joinery forum
Forum topic by Littleroom posted 07-05-2018 12:58 PM 822 views 0 times favorited 8 replies Add to Favorites Watch
View Littleroom's profile
Littleroom
9 posts in 718 days
07-05-2018 12:58 PM
I’ve made a jig for routing box joints that I found in woodsmith magazine it works quite nicely. I have found I am getting some blow out every oncs and a while. I’m using a 3/8” straight flute bit. Should I be using a spiral bit? Will it give me cleaner results?
8 replies so far
View John Smith's profile
John Smith
2135 posts in 772 days
#1 posted 07-05-2018 01:05 PM
clamping a backer board to the board being cut will “lessen the chance” of splintering.
experiment with different techniques and see what is best for your setup.
sharp spiral bits will definitely give smoother cuts.
-- I am a painter. That's what I do. I paint things --
View splintergroup's profile
splintergroup
3219 posts in 1832 days
#2 posted 07-05-2018 02:45 PM
Agreed with the backer board (front and back for perfection).
A spiral bit will work better, but try your straight bit with the backers first.
Littleroom
9 posts in 718 days
#3 posted 07-05-2018 11:05 PM
Thanks for the replies, I will try a backer boards first. I have a ton of extra hard board, would that be acceptable its all 1/8” thick stuff that I don’t know what to do with at the moment as it too small for drawer bottoms.
John Smith
#4 posted 07-06-2018 12:08 AM
practice ~ practice ~ practice
splintergroup
#5 posted 07-06-2018 01:35 PM
Thanks for the replies, I will try a backer boards first. I have a ton of extra hard board, would that be acceptable its all 1/8” thick stuff that I don t know what to do with at the moment as it too small for drawer bottoms.
- Littleroom
Give it a try, but that may be a tad thin (maybe double it up?). I usually use scrap wood, 1/2 or so thick.
You can reuse the same backer pieces over again, or rip the fingered end off at the table saw for a fresh surface.
View AlaskaGuy's profile (online now)
AlaskaGuy
5523 posts in 2919 days
#6 posted 07-06-2018 03:20 PM
Not much help here but this is why I like to do them on the table saw with a dado blade. No tear out.
splintergroup
#7 posted 07-07-2018 02:36 PM
I do prefer the TS method. All the cutting forces cause chip out on the back side (which the backing board on the miter gauge prevents).
Setup is a bit finicky, but much faster and wear/tear on the blade is insignificant.
Many (most) of the box joint jigs are identical in function and can easily be adapted for the table saw.
View johnstoneb's profile
johnstoneb
3131 posts in 2782 days
#8 posted 07-07-2018 03:34 PM
slow your feed rate down some especially as you come out of the cut. Backer board will definitely help also.
-- Bruce, Boise, ID
