Mitered Bevel
« back to Joinery forum
Forum topic by Gerald Thompson posted 07-04-2018 03:44 PM 655 views 0 times favorited 11 replies Add to Favorites Watch
Gerald Thompson
1234 posts in 2835 days
07-04-2018 03:44 PM
This is the third doll cradle my wife, Susan, and I have made. They are all the same design. We had to get updated plans as the first one was lost. The sides have a 10d bevel as the ends. The end sides have are mitered @ 10d with a 3d bevel. We preassembled the four pieces and taped them together. No matter what we did the end pieces show a gap of credit card thickness on one side abutting the side of the cradle. As they are beveled they match up great on the inside. We followed the direction exactly and even made two test ends which fit fine.
The carcass is glued and doweled and I see no way to hide the gaps. I have tried several tests on scrap, e.g., hot hide glue and sanding dust, TimberMate and varnish mixed with dust. The all stick out like a sore thumb. I am, at this time, just going to say to hell with it and finish it an get on to another project.
Any other methods of making this less obvious?
-- Jerry
11 replies so far
View 000's profile
000
2859 posts in 1500 days
#1 posted 07-04-2018 03:56 PM
Cut a sliver out of the same wood and glue it in.
View jerryminer's profile
jerryminer
960 posts in 2042 days
#2 posted 07-04-2018 04:52 PM
- jbay
Or cut a small groove along the gap and inlay an accent strip (error becomes “design feature”)
jerryminer
#3 posted 07-04-2018 05:10 PM
FWIW, when I crunch the numbers for a 4-sided box with the sides having a slope that is 10 degrees off of vertical, I get a miter angle of 9.9 degrees, and a bevel angle of 1.7 degrees (not 3)
View Aj2's profile
Aj2
2645 posts in 2399 days
#4 posted 07-04-2018 05:27 PM
Gerald spend the time dialing in your cutting method. Compound meters are very difficult but it can be done. Two things come to mind meticulous saw setup and stock prep.
Before you know it you’ll be saving time and your mind.
-- Aj
Gerald Thompson
#5 posted 07-04-2018 06:06 PM
Jerry, that must be the solution. I test fit a strip in the gap and it does not look good. I’m doing to keep the gap. All the pieces we cut right on the money according to the instructions. I’ just going to live with it. I figured the instructions were right on. Thanks everyone.
-- Jerry
Gerald Thompson
#6 posted 07-04-2018 06:34 PM
Jerry; I have hardly any math skills. Is there a web site that one can punch in the numbers to check what is instructed in the drawings?
-- Jerry
View 000's profile
000
#7 posted 07-04-2018 06:58 PM
How tall are you pieces Gerald?
Gerald Thompson
#8 posted 07-04-2018 07:30 PM
The back piece is cut from a piece 12.5’‘W, X 9 3/8’’ tall. The miter cut begins 1 5/8'' in from the bottom edge. The bottom is beveled 10d.
The front is cut from a a piece 12’‘W X 8’’ tall. The miter starts 1 3/8'' in from the edge. This too is cut 10d on the bottom. This is so the ends line up with the 10d mitered ends of the sides.
-- Jerry
jerryminer
#9 posted 07-04-2018 08:41 PM
- Gerald Thompson
Here’s one: pdxtex.com (Note that your angle is considered an 80 deg. angle, not 10)
Gerald Thompson
#10 posted 07-05-2018 12:15 AM
Jerry; I have no idea what values to enter where. I don’t know what side A or B is and I have never heard the term included angle. You are dealing with a person that had one semester of general math 60 years ago If knew what went where I can probably get it done.
Thank you.
-- Jerry
Gerald Thompson
#11 posted 07-05-2018 11:43 AM
Jerry; I finally figured it out. I came up with the same numbers you did in your earlier post. Thanks again.
-- Jerry
