drill press adjustable height side support stands
Forum topic by hkmiller posted 07-02-2018 04:43 PM 609 views 0 times favorited 6 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
180 posts in 683 days
07-02-2018 04:43 PM
I’m looking for some adjustable-height stands to put on the left and right side of my drill press table top so I can go up and down relative to the height of the product I’m drilling don’t know if there’s some that you can purchase or if someone has some easy plans to fabricate please let me know thank you
-- always something
View DBDesigns's profile
DBDesigns
232 posts in 599 days
#1 posted 07-02-2018 04:55 PM
I bought an adjustable height roller at Harbor Freight for a reasonable price recently. I can’t remember what I paid but it couldn’t have been that much or I wouldn’t have bought it. It raises to a height of about 4’ which works for my band saw but you could put it on a platform if you need it to be taller. It could also be adjusted to attach to your drill press if you want.
Good luck,
Tim
-- I remember when Grateful wasn't Dead
hkmiller
#2 posted 07-03-2018 11:53 AM
I bought an adjustable height roller at Harbor Freight for a reasonable price recently. I can t remember what I paid but it couldn t have been that much or I wouldn t have bought it. It raises to a height of about 4 which works for my band saw but you could put it on a platform if you need it to be taller. It could also be adjusted to attach to your drill press if you want.
Good luck,
Tim
- DBDesigns
DB, thanks for the reply. Sounds like what I need. I will check them out.
-- always something
hkmiller
#3 posted 07-03-2018 11:59 AM
Is this the item?
My drill press is on bench so this would not work – too high
https://m.harborfreight.com/catalogsearch/result/index/?dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf%2CSale+Rank%2Cf&q=Roller+stand
-- always something
View Kazooman's profile
Kazooman
1408 posts in 2554 days
#4 posted 07-03-2018 12:06 PM
I bought a pair of the Harbor Freight rollers to use with my table saw. They are really well built. The top flips over to choose between a simple roller or a set of ball casters that allow movement in any direction. The link above is correct. At that price you can hardly go wrong.
View ChefHDAN's profile
ChefHDAN
1496 posts in 3451 days
#5 posted 07-03-2018 03:24 PM
FWIW, I bought two of the Home depot flip top stands years ago for my TS out feed. I rarely grab my roller stand because of the stability and total height of these over the roller stand. I’ve built an out feed table since but use these all the time for my band saw, drill press, panel in feed to the TS, and even use the two of them with a hollow core door to get an extra table for the shop when needed for temporary projects. Yes twice what you’ll bay for the HF roller, but I’d recommend you take a look at them, because they are much more useful. If you live in the DC area, shoot me a PM & I’ll give you the roller stand I never use.
View Holt's profile
Holt
280 posts in 3230 days
#6 posted 07-03-2018 05:37 PM
Bought mine there too, though not recently. No real art. They go up, down, lock the height, and the rollers roll. If you buy a bunch then you eventually never need to adjust them <g>.
-- ...Specialization is for insects.
