How should I clean up this plane ?
« back to Hand Tools forum
Forum topic by Clarkswoodworking posted 06-27-2018 11:52 PM 666 views 0 times favorited 7 replies Add to Favorites Watch
View Clarkswoodworking's profile
Clarkswoodworking
289 posts in 738 days
06-27-2018 11:52 PM
I just picked up this Craftsman jointer plane
It is in good shape but has some light surface rust
Question is how should I clean it ?
Light sanding with really fine paper ?
Any suggestions appreciated
Thanks
Scott
7 replies so far
View Don W's profile
Don W
19424 posts in 3172 days
#1 posted 06-28-2018 12:03 AM
wd-40 or simple green and a rust eraser, scotch brite pad or steel wool.
A fine wire wheel will work as well on the non painted parts.
View bandit571's profile
bandit571
24370 posts in 3287 days
#2 posted 06-28-2018 01:07 AM
Made by Millers Falls for Craftsman…..almost the same as a No. 22c…..
Wire wheel on the lever cap, to polish it up…and clean the grooved sole…
View JCamp's profile
JCamp
1037 posts in 1155 days
#3 posted 06-28-2018 01:32 AM
Soak in white vinegar for a day then sand it all smooth till your satisfied with the shine. Don’t wire wheel any of the screw threads. I did that to get the rust off a badly worn cheap plane once and had to replace all the screws with new ones cause I’d taken the threads down to far. Thanks goodness it wasn’t a very good plane. Just oil them up real good
Also if the black needs touched up rustoleum is good for that
-- Whatsoever thy hand findeth to do, do it with all thy might
View OSU55's profile
OSU55
2500 posts in 2594 days
#4 posted 06-28-2018 12:20 PM
I prefer Evaporust – turns all of the rust dark. Brush excess rust off first. Scotchbrite after. Use a fine wire wheel on all threads. I apply Alox over everything for a rust inhibitor, wax the sole and all threads. I use wax diluted with ms to lube pivot points. I do not use oil – collects dust. I dont rehab totes or knobs, I make new ones of my preferred design – dwgs in my blog. How to tune a plane here.
Clarkswoodworking
#5 posted 06-28-2018 11:38 PM
Well I just used some WD40 and a green pad and she came nice and clean
Used the dremel wire wheel on the front part
Happy camper now
Thanks for the replies
Scott
View Dwain's profile
Dwain
602 posts in 4463 days
#6 posted 06-29-2018 12:18 AM
Yep, light surface rust doesn’t take much to remove. Glad to see you cleaned her up…
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
JCamp
#7 posted 06-29-2018 01:26 AM
Looks purdy now :)
