Delta Unisaw Extension Table Adapter 422-27-001-0001
Forum topic by BruceA150 posted 06-27-2018 01:47 PM 1339 views 0 times favorited 4 replies Add to Favorites Watch
View BruceA150's profile
BruceA150
2 posts in 745 days
06-27-2018 01:47 PM
Topic tags/keywords: unisaw extension table tool
Hi All-
I bought a used Unisaw with the extansion table detached. Missing the legs and the table adapter.
The part number for the adapter is above, but when I look for it online everywhere I see it says it’s no longer available.
Does anyone have any idea where I could get one so I don’t have to make one myself? Or do you know of a good workaround?
Thank you!!!
View MrUnix's profile
MrUnix
7576 posts in 2800 days
#1 posted 06-27-2018 04:04 PM
Isn’t that just a flat piece of metal with some holes in it? Seems like it would be pretty easy to figure a way to either make one – or just attach it like the old Biesemeyer extension tables did without one.
woodbutcherbynight
6033 posts in 3010 days
#2 posted 06-27-2018 04:08 PM
Need a picture of the part. Try https://www.ereplacementparts.com/ and type in your model number. That will give a exploded diagram of this part for your saw. Post that and maybe someone has one.
Best of luck, always hard finding parts branded obsolete.
View Rich's profile
Rich
5126 posts in 1190 days
#3 posted 06-27-2018 09:14 PM
Isn t that just a flat piece of metal with some holes in it? Seems like it would be pretty easy to figure a way to either make one – or just attach it like the old Biesemeyer extension tables did without one.
- MrUnix
+1. Mine’s just a piece of melamine with legs. You should be able to make one quite easily. There should already be threaded mounting holes in the side of the saw, so some angle brackets will allow you to attach it.
woodbutcherbynight
#4 posted 06-27-2018 09:28 PM
DO NOT several; of the cheap stamped steel extensions and bolt them together!!! Went to a friends house on day where he showed me his “DIY extension table”. Yeah it was functional but a solid top would be much better and provide a FLAT surface.
As Rich said you can make one fairly easily. Basically a frame with MDF and a Formica top. T-tracks can be bought and you can have them as well if so desired. Same idea as building a router extension wing.
