What operations do you use your hand planes for?
« back to Hand Tools forum
Forum topic by weekendwoodguy posted 06-26-2018 05:07 PM 1355 views 0 times favorited 13 replies Add to Favorites Watch
View weekendwoodguy's profile
weekendwoodguy
22 posts in 929 days
06-26-2018 05:07 PM
Topic tags/keywords: question milling hand plane
I have 2 mediocre hand planes and I don’t use them much. I’m sure there’s lots of operations that could be helped out by the use of a hand plane like using them with shooting boards or chamfering edges etc.
I’m curious what are the things that most often send you reaching for a hand plane?
13 replies so far
View LittleShaver's profile
LittleShaver
695 posts in 1501 days
#1 posted 06-26-2018 06:04 PM
Jointing edges
Chamfering
Shooting ends
Router Plane for tenons, lap joints, cleaning grooves
Thicknessing and smoothing
-- Sawdust Maker
View TheFridge's profile
TheFridge
10861 posts in 2368 days
#2 posted 06-26-2018 10:00 PM
Ditto with the exception of jointing edges.
View corelz125's profile
corelz125
1596 posts in 1858 days
#3 posted 06-26-2018 10:51 PM
all depends on which planes you have
View jayseedub's profile
jayseedub
169 posts in 2847 days
#4 posted 06-26-2018 11:04 PM
Mostly for jointing edges and chamfering.
I have a low-angle block plane, a No. 4 equivalent, and two home-made wooden planes (Jack and Jointer lengths).
Wish I had a low-angle Jack and a shooting board for it.
View DIYWoodGuy's profile
DIYWoodGuy
9 posts in 851 days
#5 posted 06-26-2018 11:16 PM
Joining edges. Shooting endgrain on a shooting board. Chamfering edges. Face joining prior to planing of over 6”.
View bandit571's profile
bandit571
26722 posts in 3565 days
#6 posted 06-26-2018 11:38 PM
Jointing edges
thicknessing after a resaw
clean up dovetail joints after a glue up.
Flattening a glued up panel
Beveling an edge
Making a raised panel
smoothing a surface to be ready for a finish.
Some planes will do rebates, dados, tongue & groove joints, and moldings
Block planes to shoot an end of a board, and knock the sharp edges off the edges of boards.
When I do get rough-sawn lumber, a cambered jack will work it down to where it is closer to S4S stock…
weekendwoodguy
#7 posted 06-27-2018 12:59 AM
For flattening a glued up panel would you use a smoothing plane? Would the dimensions of the wood determine your choice of plane? I’m assuming that you panels would already be pretty flat before glue up.
View JCamp's profile
JCamp
1229 posts in 1433 days
#8 posted 06-27-2018 01:23 AM
Even if I didn’t use them I’d still keep some around to look at :)
-- Whatsoever thy hand findeth to do, do it with all thy might
weekendwoodguy
#9 posted 06-27-2018 01:27 AM
- corelz125
I should have said in my original post I have a Stanley Handyman and a no name block plane. They were both my dad’s and I got them free so no complaints here although I know people really don’t like the Handyman line. I sharpened them up on my whetstones but other than chamfering I haven’t done much with them.
View JohnChung's profile
JohnChung
421 posts in 2956 days
#10 posted 06-27-2018 03:21 AM
- weekendwoodguy
I will not try so as the sole will get damaged. For smoothers it is very important to have pristine sole.
But it depends on your space and budget. If you have a #4 only then there is no choice. It becomes your
jack plane.
View OSU55's profile
OSU55
2658 posts in 2871 days
#11 posted 06-27-2018 12:38 PM
I m curious what are the things that most often send you reaching for a hand plane?
- weekendwoodguy
Replace sandpaper – all surfaces get smoothed with a plane
Flatten panel glue ups – they are never perfectly flat
Joint edges – I dont own a powered jointer, dont need it
Misc – clean up rabbets, ease or chamfer edges, prep turning blanks, etc
I dont use them to dimension lumber – I use a pwr planer
View Sludgeguy's profile
Sludgeguy
59 posts in 1004 days
#12 posted 06-27-2018 02:00 PM
As OSU55 said, panel glues are never perfectly flat and the hand plane is usually the tool of choice for flattening.
I use them all the time for this. Typically, a No. 5 and a No. 7.
View gargey's profile
gargey
1013 posts in 1657 days
#13 posted 06-27-2018 02:07 PM
What? Glue lines will not damage a handplane.
- weekendwoodguy
jack plane.
- JohnChung
