Anything worthwhile in here ?
« back to Hand Tools forum
Forum topic by Clarkswoodworking posted 06-25-2018 03:45 PM 816 views 0 times favorited 16 replies Add to Favorites Watch
View Clarkswoodworking's profile
Clarkswoodworking
289 posts in 741 days
06-25-2018 03:45 PM
Local ad
$100 for all
Just wondering if anything worth restoring in this group
I cannot tell one from the other
Thanks
Scott
16 replies so far
View JCamp's profile
JCamp
1040 posts in 1158 days
#1 posted 06-25-2018 03:55 PM
Id say they are all worth the $10 a piece even if just for parts. Some others will likely chime in that can tell you what they are base on the pics but I cant tell
-- Whatsoever thy hand findeth to do, do it with all thy might
View kkaucher's profile
kkaucher
23 posts in 927 days
#2 posted 06-25-2018 04:01 PM
I’d have to agree with JCamp – $10 each is a fair price – you’d lose nothing and you may find a treasure gleaming in the stack. Will the seller not provide any more detail? That may be worth the effort.
I doubt that it would be much work to restore them. Nothing looks too horribly rusted, not much in the way of physical damage. No funny colors that one might expect on a cheapie plane. I’d go for it just for giggles!
-- A bad day woodworking is better than a good day working. ~Author unknown
View Rich's profile (online now)
Rich
5145 posts in 1197 days
#3 posted 06-25-2018 04:06 PM
Looks like junk to me. Missing knob, chipped totes, and what looks to be potentially deep pitting. The transitional plane could be cool with new wood, assuming it cleaned up nicely.
View DBDesigns's profile
DBDesigns
232 posts in 605 days
#4 posted 06-25-2018 04:27 PM
If this was on EBAY I would avoid it because the shipping would cost too much to make the price worth while. Also, the photos don’t show the bottoms and sides of the planes very well. Cracks and chips at the mouth basically render the planes unusable.
The wooden jack plane looks like junk. It appears to be badly checked and cracked along the grain of the wood.
There does appear to be a decent number 9 and some decent smoothing planes in the bunch but it doesn’t look like any prizes are in there. Don’t be afraid of rust. It’s easy to remove with vinegar and it hides a lot of good cast iron.
I would say that if you can look at the lot before you pay, it might be worth pursuing. Also, there are a lot of Stanley plane parts available on EBAY for a reasonable price.
-- I remember when Grateful wasn't Dead
View JayT's profile
JayT
6361 posts in 2819 days
#5 posted 06-25-2018 04:28 PM
There’s definitely the value there if you want to do the restorations. I see some that are easily identifiable as Stanley Bailey’s and most are complete.
Learn on the one with the chrome lever cap (least valuable of the lot as I see it) and then progress up to the others. The missing knob is easily replaced by buying or turning one.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View BlasterStumps's profile
BlasterStumps
1494 posts in 1047 days
#6 posted 06-25-2018 04:36 PM
What you can’t see matter most and that is if the mouth corners or the heel are broken/cracked.
Top pic: big plane on left looks like it could be a Union. Smaller plane next to it might be a Stanley. Little block plane might be cool. Has a knuckle joint lever cap. Might be an 18. $100 would be a bit of a stretch for me on those. Transitional planes, well…
Mike
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
DBDesigns
#7 posted 06-25-2018 04:39 PM
One more thing. If you do choose to restore these or any other quality antique planes, avoid using a wire wheel to remove surface rust and dirt. The natural grain of the iron will disappear and be replaced by a finish that will rust faster. Also, everyone will be able to tell that it was restored with a wire wheel and that makes it less desirable.
View bondogaposis's profile
bondogaposis
5605 posts in 2959 days
#8 posted 06-25-2018 04:39 PM
I’d say it is worth it. Surely you could re-coup the $100 by fixing a few up and reselling them.
-- Bondo Gaposis
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#9 posted 06-25-2018 04:44 PM
All it takes is 2 in good shape. Wire wheels are awesome.
DBDesigns
#10 posted 06-25-2018 06:05 PM
Yo Fridge,
Wire wheels have their place. PBR is awesome!
DBDesigns
#11 posted 06-25-2018 06:12 PM
TheFridge,
See y’all in Death Valley this fall for the way too infrequent Dawgs vs. Tigers extravaganza. Last time we played y’all in Athens I gained about 5 lbs just form the LSU fans sharing their tailgate fair. What a party!
Rich
#12 posted 06-25-2018 06:22 PM
Yo Fridge,
- DBDesigns
Having taken an entire semester of Material Science in engineering school, I’m finding your wire wheel argument questionable. Do you have anything to support the statement that the natural grain of the “iron” will be removed, and that that will lead to it rusting faster?
My lab work in class indicated that the only thing that will change the grain structure of steel is heat.
DBDesigns
#13 posted 06-25-2018 06:42 PM
Here’s what I’m talking about. No mechanical method will alter the molecular structure of the iron without heat. You are right about that. When the planes were sold new, they had “Grain Marks” that are in a parallel direction with the sole. If the plane body is sanded along a flat surface with sand paper taped there, like a jonter top or a tablesaw, you will get a beautiful reproduction of how it came from the original maker. The finer the grit the better. A wire wheel allows it to rust more because the microscopic dents the wheel puts in the surface add more unprotected surface area. Also, the sole of the plane depends on it’s flatness to perform properly and a wire wheel does not contribute to a flat surface.
BTW, I hated my materials science class. All that crystalline structure mumbo jumbo just gave me a headache.
View ElroyD's profile
ElroyD
134 posts in 1196 days
#14 posted 06-25-2018 06:43 PM
I’d restore them just for the practice of restoring them. If you find afterwards that they are worth selling, you could always do so.
-- Elroy
View Don W's profile
Don W
19433 posts in 3175 days
#15 posted 06-27-2018 11:46 PM
Are they in your shop yet?
