Festool ETS 150 question
Forum topic by ChicagoHiker posted 06-08-2018 12:03 AM 478 views 0 times favorited 3 replies Add to Favorites Watch
View ChicagoHiker's profile
ChicagoHiker
56 posts in 2408 days
06-08-2018 12:03 AM
Recently the sandpaper has begun coming loose from my Festool ETS 150. Does this mean that the velcro sander pad needs to be replaced?
Thanks for any suggestions!
-- Paul Segedin, Chicago, IL http://urbanprairiedesign.com/
3 replies so far
View splintergroup's profile
splintergroup
3201 posts in 1826 days
#1 posted 06-08-2018 03:51 PM
Could be, but make sure your paper is not all dusty on the back and the pad is also clean (use compressed air).
The pads “grabby” bits will last a long time if the sander is not used too aggressively (excess pressure, non-flat surfaces being sanded, etc.) The enemy is heat which softens up the plastic and causes the little whiskers to fold over.
If you do replace, be aware that there are different stiffnesses of pads, from flat and firm to spongy.
View AandCstyle's profile
AandCstyle
3258 posts in 2860 days
#2 posted 06-08-2018 09:53 PM
Paul, try Splinter’s suggestions, but I have had to replace replace the pad once or twice. I use the medium hardness one, FWIW.
-- Art
ChicagoHiker
#3 posted 06-09-2018 01:39 AM
Thanks for the suggestions!
