Retro fitting a lock?
Forum topic by leftcoaster posted 06-07-2018 12:37 PM 469 views 0 times favorited 4 replies Add to Favorites Watch
View leftcoaster's profile
leftcoaster
284 posts in 1481 days
06-07-2018 12:37 PM
A friend was burglarized a year or so ago. Apparently the thief used a metal detector to locate the drawer where jewelry could be taken as no ransacking took place aside from that.
Having been burned once, he wants to take some preventive measures.
They have a dresser with small, shallow drawers. Is there available hardware that he can install to lock it without drilling a lock into the drawer front? His idea was an electronic lock that opens with a fob. If unplugged it would remain locked.
Other ideas or sources for hardware?
View John Smith's profile
John Smith
2131 posts in 767 days
#1 posted 06-07-2018 01:01 PM
my idea would be to get a wall safe and bolt it to the studs inside a closet.
I’m thinking the carcass of a dresser could easily be breached with a small crowbar.
-- I am a painter. That's what I do. I paint things --
View Rich's profile
Rich
5136 posts in 1193 days
#2 posted 06-07-2018 01:59 PM
My dad used to say that locks keep the honest people out. If a criminal wants it — he’ll get it. Safes are good to have for protecting things from the heat if there’s a fire, and they can be secured with varying levels of strength. If you want real security, get a safe deposit box at the bank. I think locks on a dresser are a waste of time other than to keep the kids out.
Back to your question, a great solution would be to build a concealment piece of some sort. Things like tissue box covers with false bottoms, wall mounted coat hangers that can swing open, picture frames with hidden areas, or any number of other ideas would serve to hide valuables pretty well. Again, not foolproof, but better than a locked dresser.
As far as the metal detector goes, use metal coat hooks on a coat hanger, or metal embellishments on a box with a hidden compartment and a positive read from the detector won’t seem unusual.
You can use magnetic catches to latch things closed and then opened with a strong magnet pressed against a certain spot. Search around for ideas because I’ve stumbled across tons of them.
leftcoaster
#3 posted 06-07-2018 02:06 PM
View JADobson's profile
JADobson
1448 posts in 2715 days
#4 posted 06-07-2018 03:25 PM
- leftcoaster
Much more likely is that someone knew where it was already.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
