Cabinet Coat by INSL-X (satin): Anyone have Experience with it?
Forum topic by Lovegasoline posted 06-06-2018 07:43 PM 691 views 0 times favorited 5 replies Add to Favorites Watch
View Lovegasoline's profile
Lovegasoline
85 posts in 641 days
06-06-2018 07:43 PM
I’m stripping and refinishing my kitchen cabinets in a white color. I was initially going to use Satin Impervo Waterbase, which I’ve used for trim, door & wndow frames, bookcases, etc. (all brushed on) but I’ve heard good things about Cabinet Coat and think it will make a tougher surface for high use cabinets as opposed to the waterbase Impervo.
I’d like to spray it with my HVLP gun and would like to get some input if anyone has some experience with spraying the product.
Thanks a bunch!
5 replies so far
View Rich's profile
Rich
5134 posts in 1192 days
#1 posted 06-07-2018 01:22 AM
I can’t comment on the Cabinet Coat product, but regarding spraying it, I recommend getting a Ford #4 viscosity cup and using it, combined with the spray tip chart for your HVLP gun, to determine the correct tip size for its viscosity and/or thinning for your tip size.
View AlaskaGuy's profile
AlaskaGuy
5520 posts in 2912 days
#2 posted 06-07-2018 04:23 AM
I can t comment on the Cabinet Coat product, but regarding spraying it, I recommend getting a Ford #4 viscosity cup and using it, combined with the spray tip chart for your HVLP gun, to determine the correct tip size for its viscosity and/or thinning for your tip size.
- Rich
At the bottom of this page is a handy chart.
http://homesteadfinishingproducts.com/wp-content/uploads/2014/05/paintspraying_ver3.pdf
View Rich's profile
Rich
#3 posted 06-07-2018 04:37 AM
- AlaskaGuy
Good link from AG. Jeff always has the best info. I’d also recommend a wet film thickness gauge for test sprays. They’re under $10 and invaluable.
Lovegasoline
#4 posted 06-08-2018 12:08 AM
Thanks for the replies.
I’ve got a wet film thickness gage somewhere and also a cheap plastic viscosity cup (lent my metal one out and never got it back).
I’ll look through the literature. If anyone has used this product I do have some questions.
And it’s been a long time since I’ve sprayed. I’ve got a fantastic clearcoat gun (LVLP) and also a cheaper primer gun which I’ve used for spraying colored conversion varnish. I’m hoping the primer gun will be able to handle the viscosity of the Cabinet Coat.
View John_'s profile
John_
225 posts in 2309 days
#5 posted 06-08-2018 01:51 AM
Take a look at General Finish pigmented poly in white. I have used their black in various sheens and have been very happy with the results. It is designed to only be sprayed. HVLP: 1.3mm-1.5mm spray tip, medium air cap
https://generalfinishes.com/wood-finishes-professional/water-based-paints-glazes-and-pigmented-top-coats/enduro-pigmented-white
