Should I be worried about a few damaged blade teeth?
Forum topic by Dustin posted 06-05-2018 07:51 PM 2968 views 0 times favorited 21 replies Add to Favorites Watch
View Dustin's profile
Dustin
705 posts in 1343 days
06-05-2018 07:51 PM
Topic tags/keywords: question tablesaw
As I was changing from my 10” combo blade to my rip blade the other night, I noticed 3-4 teeth with very slight dings/chips in them. I’ve been using the blade without incident, and I did check where the carbide meets the blade (no apparent damage). My question is: Is it safe to continue using with just a few teeth with minor damage, or am I just asking for trouble?
If necessary, I can upload some pictures later.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
21 replies so far
View Bill White's profile
Bill White
5242 posts in 4563 days
#1 posted 06-05-2018 07:56 PM
Just me, but I DON’T use a damaged blade under any circumstances.
-- [email protected]
View Loren's profile
10477 posts in 4251 days
#2 posted 06-05-2018 07:56 PM
I do it. They seem to get chipped here and there
just cutting wood.
I suppose a blade could throw a chip. I use a guard
and don’t recall ever finding one.
View knotscott's profile
knotscott
8352 posts in 3978 days
#3 posted 06-06-2018 02:03 AM
If it’s a decent blade, have it sharpened. If its a cheap blade, replace it with a better one.
woodbutcherbynight
6034 posts in 3012 days
#4 posted 06-06-2018 02:12 AM
If it s a decent blade, have it sharpened. If its a cheap blade, replace it with a better one.
- knotscott
+1 because Father Murphy tends to show up and a trip to the ER is alot more than a new blade.
View bigblockyeti's profile
bigblockyeti
6180 posts in 2323 days
#5 posted 06-06-2018 02:17 AM
Do you have pictures of the damage? Some blades should be replaced or repaired (if worth it) and some damage isn’t something you might need to worry about.
View BurlyBob's profile
BurlyBob
6895 posts in 2868 days
#6 posted 06-06-2018 04:48 AM
+2 for what knotscott said as well as wood butcher.
Dustin
#7 posted 06-06-2018 11:44 AM
Well, I said I’d take pictures, then totally forgot :p
The damage to the teeth being where it is (there are two teeth chipped on the side of the carbide, and 2 with significant dings on the top of the teeth), I think it’s likely necessary for those teeth to be replaced rather than sharpened. The blade is the Freud P410t, and has served me pretty well, so I’m looking at 2 options:
Contact a sharpening service and get an estimate to have it sharpened and the damaged teeth replaced (depending upon the cost, I’ll either get it repaired or buy a replacement), or
Buy a true cross-cut blade rather than another combination blade. As it is, I do take the time to swap out blades for ripping operations, so I’m interested to hear feedback on this one.
View enazle's profile
enazle
66 posts in 611 days
#8 posted 06-06-2018 01:19 PM
Man, that’s a name brand blade. Do you remember hitting anything? If no it may be defective.
Dustin
#9 posted 06-06-2018 02:14 PM
Man, that s a name brand blade. Do you remember hitting anything? If no it may be defective.
- enazle
Oh yeah. I mean, I’ve had it for almost two years, but I distinctly remember when I turned it on and a nearby drill bit fell off my fence (we just had a thread about keeping stuff off your fence, but I learned my lesson the hard way) and hit the blade.
By the by, I did find a number of sharpening services online, and it looks to run me around half the cost of the blade or less to get the teeth repaired/replaced and the blade sharpened, so I think that’s my plan. Any sharpening services you all recommend highly? Or at least, any that I should particularly avoid?
View GR8HUNTER's profile
GR8HUNTER
6800 posts in 1315 days
#10 posted 06-06-2018 03:04 PM
I take mine to an Amish guy who does an incredible job sharpening them to better then new :<))
should be some in KY :<))
Dustin
#11 posted 06-06-2018 03:17 PM
- GR8HUNTER
Lol. Yeah, there are plenty. I’m on the outskirts of a major metropolitan area, with a very rural area/farmland only about 10 miles Northeast of me. I see ‘em around all the time. Maybe I should just carry my tools with me everywhere, so I can request an impromptu sharpening? :p
View Rich's profile
Rich
5133 posts in 1192 days
#12 posted 06-06-2018 03:50 PM
Forrest sharpens blades other than their own. The exceptions are on their web site. I’m sure there are other outstanding companies doing sharpening, but they would be a sure thing.
View HokieKen's profile
HokieKen
11984 posts in 1741 days
#13 posted 06-06-2018 03:56 PM
Buy a true cross-cut blade rather than another combination blade. As it is, I do take the time to swap out blades for ripping operations, so I m interested to hear feedback on this one.
- Dustin
If you’re swapping blades when you switch between cross-cutting and ripping, I don’t see any reason to stick with a combination blade. I get much better results with dedicated X-cut and rip blades.
-- Kenny, SW VA, Go Hokies!!!
Dustin
#14 posted 06-06-2018 04:13 PM
- Dustin
If you re swapping blades when you switch between cross-cutting and ripping, I don t see any reason to stick with a combination blade. I get much better results with dedicated X-cut and rip blades.
- HokieKen
Kenny,
That was my thought, but wanted some input. I know the difference in ripping from the combo blade to rip blade is night and day. Would you say it’s a fairly dramatic improvement in cross cutting? I do already use a sled for these operations to avoid bottom/back tearout.
Either way, I’ll likely have this blade serviced as it’s too good to let go (plus, nice to have a backup).
HokieKen
#15 posted 06-06-2018 04:18 PM
- Dustin
- HokieKen
Kenny,
That was my inclination, but wanted some input. I know the difference in ripping from the combo blade to rip blade is night and day. Would you say it s a fairly dramatic improvement in cross cutting? I do already use a sled for these operations to avoid bottom/back tearout.
- Dustin
In my opinion, yes, the cut quality is much improved. But, my combo blade is a 50T Diablo blade and my X cut is a 60T Freud Industrial thin kerf. So I went up in tooth count and blade quality so it’s not exactly apples-to-apples comparison.
