a router pantograph /copier question
Forum topic by ShuheiFujikura posted 06-05-2018 10:05 AM 647 views 0 times favorited 6 replies Add to Favorites Watch
View ShuheiFujikura's profile
ShuheiFujikura
22 posts in 1680 days
06-05-2018 10:05 AM
Topic tags/keywords: question carving tool carving router resource tip pantograph copier
I picked up this engraver, made in 1972. The motor is running but those belts are missing.
I have to get V-belts for this.
If I want this machine to work as a copier, where should I put a stylus arm?
-- Shuhei Fujikura, Japan, http://www.shuheifujikura.com/
View John Smith's profile
John Smith
2135 posts in 773 days
#1 posted 06-05-2018 11:03 AM
from what I remember about the old New Hermes engravers is that
the factory design limits the machines capabilities to only engraving
flat items – and not in the up and down axis.
depending on what you want to duplicate, you would have to change out
the spindle that holds the cutters and LOT of engineering to make it a dimensional
copier. again – depending on the size of items you wanted to duplicate and in what material.
I think the spindle only holds bits up to 1/8”. the HP of the motor is also a factor.
the stylus arm must control the cutting spindle as one unit to move in unison in a fluid motion
sideways and up and down.
the elbow joint circled in red will be your first obstacle.
when you lift the stylus ~ it does not lift the cutter head the same distance.
there are many videos on YouTube about the Marlin Carving Machine that will give you an idea
of how a duplicator router works.
if you have some woodworking skills, I have seen some duplicating routers with an all wood framework
that performed quite well.
good luck !! if you proceed with this project, please post some photos as you go along.
p.s. ~ I really like your Screen Print outfit !! VERY nicely done !!!
-- I am a painter. That's what I do. I paint things --
ShuheiFujikura
#2 posted 06-05-2018 11:27 AM
Hi John, Thanks for the comment.
With the up and down axis, it has a dial to adjust though.
For 3-D movement, I guess I have to make a fore-arm to replace.
ShuheiFujikura
#3 posted 06-06-2018 01:11 AM
About the belt, does one of those leather belt for a treadle sewing machine work?
John Smith
#4 posted 06-06-2018 01:26 AM
yes – that is what I had in mind if you can find one.
joined with a staple type fastener at the ends.
a quick google search turned up some on the net: 6ft @ $7 from Amazon.
somewhere in Japan, there should be some kind of suitable substitute.
motorized garden equipment has narrow V-Belts that “might” work if you can’t find the round one.
good luck !
MrUnix
7601 posts in 2810 days
#5 posted 06-06-2018 01:36 AM
That sheave appears to be for a standard V-belt… but if the one on the arm needs to be somewhat flexable depending on arm articulation, a proper sized o-ring would probably work and have enough flex.
ShuheiFujikura
#6 posted 06-06-2018 02:51 AM
These are close-up view of the sheaves.
