Table saw blade clearance and alignment with splitter
Forum topic by hkmiller posted 06-04-2018 03:37 AM 503 views 0 times favorited 3 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
189 posts in 693 days
06-04-2018 03:37 AM
Finished my unisaw refurbishment and put the table on the saw today.
Two things: my splitter is a little left of the blade, and the blade clearance between the blade and throat plate on the right seems too close. I came move the table to the right a bit to increase clearance, but my main concern is the splitter alignment.
Is this an issue as is, or should I fix it. I will have to remove the table and move the arbor arm To the left. This would fix both issues, but don’t want to unless it is a safety issue as is.
-- always something
3 replies so far
View builtinbkyn's profile
builtinbkyn
3001 posts in 1552 days
#1 posted 06-04-2018 04:06 AM
Your splitter must align with your blade or there will be problems. It needs to fit the kerf cut created by the blade or your cut can’t be completed and a dangerous situation would ensue.
-- Bill, Yo!......in Brooklyn & Steel City :)
MrUnix
7602 posts in 2810 days
#2 posted 06-04-2018 04:20 AM
No need to touch the arbor unless it’s out of alignment with the motor pulley. Just adjust your splitter… here are the instructions:
34-868 Unisaw splitter assembly instructions
To elaborate just a bit farther – The motor pulley is installed in a fixed location (3.75” from pulley face to mounting tab – refer to the manual for instructions). The arbor is then aligned to the motor pulley, and then the table and splitter are aligned to the arbor.
hkmiller
#3 posted 06-04-2018 11:52 AM
Got it. Will adjust the splitter. I have the splitter instructions but I don’t even think to read them
-- always something
