Tooling for making panel moulding
Forum topic by SweetTea posted 06-02-2018 01:52 PM 1193 views 0 times favorited 8 replies Add to Favorites Watch
View SweetTea's profile
SweetTea
468 posts in 1269 days
06-02-2018 01:52 PM
Ok so I am wanting to make some panel moulding for the wainscoting in my home. It will go around the inside edges of the stiles and rails on my wainscoting and also cover the edges of the raised panels if I decide to do raised panels (versus just leaving it with the recessed panel look). My questions to you guys are where do I get the tooling for making panel moulding? I have multiple 3HP shapers and multiple router setups. I would prefer to make it on the shaper as that way I can use my power feeder. But I am open to doing it on the router table. If you guys could supply me with some info and possibly some links for purchasing this tooling that would be great.
8 replies so far
View MrRon's profile
MrRon
5812 posts in 3853 days
#1 posted 06-02-2018 02:17 PM
Any woodworking supply has all the moulding cutters needed to cut any profile both with shaper cutters or router bits. FYI: For an 8’ ceiling, the wainscoting should be no higher than 32” above the floor.
SweetTea
#2 posted 06-02-2018 03:41 PM
Any woodworking supply has all the moulding cutters needed to cut any profile both with shaper cutters or router bits. FYI: For an 8 ceiling, the wainscoting should be no higher than 32” above the floor.
- MrRon
Thanks for the reply. I am not understand how to find these types of cutters. I have searched but only came up with crown moulding, astrigal, chair rail, picture frame ect. ect. Nothing for panel moulding. Would there be any need for a rabbit on the back of the panel moulding?
View 000's profile
000
2859 posts in 1509 days
#3 posted 06-02-2018 04:11 PM
SweetTea
#4 posted 06-03-2018 11:47 AM
All depends on what your looking for. Pick what you like then look for the cutters to make it.
https://www.bing.com/images/search?q=panel%20moulding%20profiles&qs=IM&form=QBIRMH&sp=2&pq=panel%20moulding&sk=IM1&sc=8-14&cvid=02A2F903F3974BC19320530F10A468A9
- jbay
Ok well let’s take for example the profile on the top row fourth from the left on the link you posted. I like that one. How do I find the cutters for that profile? I have searched and searched for panel moulding cutters and can’t find any.
View waho6o9's profile
waho6o9
8812 posts in 3187 days
#5 posted 06-03-2018 01:08 PM
View 000's profile
000
#6 posted 06-03-2018 01:51 PM
Quote: I have multiple 3HP shapers and multiple router setups.
Where do you get your cutters now? They should be able to direct you.
View timberframe's profile
timberframe
13 posts in 571 days
#7 posted 07-04-2018 08:09 PM
Hi Sweet tea, not sure what you have for tooling but I would seriously consider a euroblock that allows you to change the knives for whatever profile you want, without having to buy a new head. Even better, Whitehill makes one that also contains straight carbide knives so it can work as a rebate block as well. They’re very cost effective as once you own the head, the additional profiles are cheap.
http://www.whitehill-tools.com/catalogue.php?cid=2&c2id=60
I own one if you have any questions.
B
View Jared_S's profile
Jared_S
277 posts in 569 days
#8 posted 07-06-2018 08:54 PM
- jbay
- SweetTea
That profile is available from CMT, amana, Dimar ect… in a 40mm pin knife.
Or preferably if you have a moulder there are a bunch of sources, but it’s a stock w&h knife.
