Chisel hoops, where can I buy them???
« back to Hand Tools forum
Forum topic by Dreban posted 06-01-2018 08:44 PM 919 views 0 times favorited 3 replies Add to Favorites Watch
View Dreban's profile
Dreban
64 posts in 1253 days
06-01-2018 08:44 PM
Howdy,
I have an old, PS&W No 1 EX 2” wide x 17” long heavy framing chisel that the former user had beat the stuffing out of over the years, building houses in Alaska. It had a split handle and the iron hoop was folded over and ruined. I had to cut/drill the handle out and I’d like to turn a new one. I’ve been using it with an old, cut-off shovel handle with duct tape around the end and it’s mushroomed over that nicely, but it’s days are limited. haha.
Anyone have any idea where I can buy a replacement hoop for the end of the new handle I turn? I’ve seen lots of links on how to SET a hoop on a Japanese handle, but nothing on where I buy them. I checked Etsy with no luck.
Thanks in advance for the help.
3 replies so far
View Loren's profile
11271 posts in 4891 days
#1 posted 06-01-2018 08:49 PM
Cut off a piece of pipe and turn/carve your
handle to accept it. If you have a welder
a hoop could be made, crudely perhaps.
A blacksmith can make a ring and size it
using a mandrel.
I think I’ve seen riveted hoops of thin copper
but they don’t look very sturdy.
View John Smith's profile
John Smith
3007 posts in 1406 days
#2 posted 06-02-2018 05:34 PM
assuming you have a lathe, like Loren says – pipe and fittings often work well.
collecting scrap pieces of pipe and fittings that you see laying around
can be a treasure trove of goodies in times like this.
brass, stainless, copper, Cu-Ni, iron, etc.
also, look in the speciality parts bins at the Big Box stores
to find bronze bushings – they come in many different sizes.
easily cut with a hacksaw or angle grinder cutoff wheel.
cut the metal ferrule/hoop first, then turn the handle on the lathe to fit the ferrule/hoop.
-- I am a painter: that's what I do, I like to paint things. --
Dreban
#3 posted 06-03-2018 02:49 AM
Thanks for the info!
