How do you cross cut on your table saw???
Forum topic by scribble posted 05-31-2018 09:01 PM 1575 views 0 times favorited 23 replies Add to Favorites Watch
View scribble's profile
scribble
216 posts in 2808 days
05-31-2018 09:01 PM
Topic tags/keywords: question tablesaw milling
I am looking to see how people do cross cutting on there table saws. Are you using a sled of some sorts or just using a miter gauge.
-- If you can't read it Scribble wrote it!! “Experience is merely the name men gave to their mistakes.”
23 replies so far
View bondogaposis's profile
bondogaposis
5605 posts in 2959 days
#1 posted 05-31-2018 09:04 PM
For short pieces I use the miter gauge with an sacrificial fence, longer pieces I use a sled and for really long pieces I cut to rough length with a circular saw or miter saw.
-- Bondo Gaposis
View MrUnix's profile
MrUnix
7597 posts in 2806 days
#2 posted 05-31-2018 09:12 PM
- scribble
Yes.
View knotscott's profile
knotscott
8364 posts in 3983 days
#3 posted 05-31-2018 10:00 PM
Osborne EB-3 miter gauge with fence that has stop block and a sandpaper face.
View jdmaher's profile
jdmaher
463 posts in 3187 days
#4 posted 05-31-2018 10:02 PM
Rough cuts with a miter gauge. Final / finish cuts with a sled (Dubby).
In fact. most of the cuts are done with the sled. I’ll sometimes do rough cuts with a hand or circular saw (biggish lumber), and I have enough off-cuts of my favorite woods that I can usually select a piece that’s close enough to finish size. And the particular sled I’m using makes it real easy to dial in a length and reliably repeat it.
-- Jim Maher, Illinois
View Walker's profile
Walker
193 posts in 1080 days
#5 posted 05-31-2018 10:31 PM
How do I cross cut on my table saw? I lift the wood right over it and make the cut on my miter saw.
Joking aside, I only have a cheap contractor saw (no space or money for a real table saw). I have a sled I use, made with Micro Jig’s “Zero Play” miter bars which is okay, but the saw is so inaccurate I needed to find a better way. I bought a nice sliding compound miter saw. The cut capacity is big enough for most jobs. Now I leave the table saw set up for rip cuts most of the time.
-- ~Walker
View Andre's profile
Andre
3012 posts in 2413 days
#6 posted 05-31-2018 10:33 PM
Short pieces Kreg miter gauge, real small and repeatable cuts sled, hacking planks down to size Hand saw!
View builtinbkyn's profile
builtinbkyn
2999 posts in 1548 days
#7 posted 05-31-2018 10:34 PM
Same as Bondo.
-- Bill, Yo!......in Brooklyn & Steel City :)
Rick Dennington
6789 posts in 3802 days
#8 posted 05-31-2018 11:21 PM
I have 4 different size sleds for different size woods…..I hardly ever cross cut with a miter gauge….Depending on what I have to have, I also cross cut with my radial arm saw….Then move it to one of the sleds….!!
-- " There's a better way.....find it"...... Thomas Edison.
View TheFridge's profile
TheFridge
10859 posts in 2093 days
#9 posted 05-31-2018 11:28 PM
Both
View Charlie H.'s profile
Charlie H.
395 posts in 1258 days
#10 posted 06-01-2018 12:22 AM
I have the stock miter gauge locked at 90 degrees with a long laminated plywood sacrificial face and it’s equipped with a flip stop.
I mostly use that in the right miter slot when I cut 45 degree bevels.
I have an Incra HD1000 that I use in the left miter slot, it’s good for batching out parts.
I use the crosscut sled a lot.
It is especially useful for small parts.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View BroncoBrian's profile
BroncoBrian
875 posts in 2566 days
#11 posted 06-01-2018 12:30 AM
Yep, same as above. Icra Miter, and crosscut sled.
I think the Incra V27 is a great value and you can add a face to it.
-- A severed foot is the ultimate stocking stuffer.
woodbutcherbynight
6052 posts in 3016 days
#12 posted 06-01-2018 01:39 AM
These two are the most commonly used ones. I have a larger sled but no pics. Nothing fancy, no special miter bars just wood screws and some glue. Little time tuning them up and they have remained accurate.
View MrWolfe's profile
MrWolfe
619 posts in 731 days
#13 posted 06-01-2018 01:45 AM
I have an Osbourne EB-3. I use it for most cuts. There is even a video on how to use it for crosscutting panels.
I will probably make a dedicated small parts sled but I use the EB-3 for everything else. I sometimes rough cut full sheets with a circular saw and cut them to finish on the table saw too.
https://www.youtube.com/watch?v=_RcChmHntes&t=10s
View clin's profile
clin
1076 posts in 1603 days
#14 posted 06-01-2018 03:22 PM
I use a sled for all cross cuts. I only use my Osborne miter gauge if making an angled cut.
-- Clin
View Derek Cohen's profile
Derek Cohen
480 posts in 4576 days
#15 posted 06-01-2018 03:49 PM
Hammer K3 Slider …
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
