Hitachi C10FCH2 miter saw laser guide fade in full sun light...is it normal?
Forum topic by MiniMe posted 05-31-2018 03:29 PM 1913 views 0 times favorited 6 replies Add to Favorites Watch
View MiniMe's profile
MiniMe
323 posts in 659 days
05-31-2018 03:29 PM
Hi guys
i just bought this saw and I am trying to use it outside
I am surprised that the laser mark on the boards is barely visible. Did I get a lemon or this is normal?
View mel52's profile
mel52
1202 posts in 872 days
#1 posted 06-01-2018 02:55 AM
I am guessing that it is a normal problem in daylight. I have a big 12’’ sliding dual compound and a smaller one and they both are hard, if not impossible to see in daylight. Same with a big skill saw I have. I try to set them up where the sun isn’t directly on that area I’m cutting. This doesn’t really bother me as I use my eyes to set the cut line, afraid the light might be off a little.
-- MEL, Kansas
woodbutcherbynight
6052 posts in 3016 days
#2 posted 06-01-2018 03:22 AM
Normal condition.
MiniMe
#3 posted 06-01-2018 11:06 AM
Thank you guys
View Woodtodust's profile
Woodtodust
71 posts in 2445 days
#4 posted 06-01-2018 11:42 AM
I have the same saw and I often have to shut my garage (workshop) door to see the laser. The light on mine is very accurate. Great saw.
-- Bill...Richmond Hill, GA--"83% of all statistics are made up."
MiniMe
#5 posted 06-01-2018 12:52 PM
Yes I can confirm that …it is indeed accurate when you can see it
I am wondering if the laser can be upgraded to stronger more powerful diode
View Kazooman's profile
Kazooman
1408 posts in 2560 days
#6 posted 06-01-2018 01:24 PM
- MiniMe
You could do one better and get a really powerful laser. Then you wouldn’t even need the saw blade! It would eliminate all that pesky sawdust too. Might set off the smoke detector though.
I have a similar problem with a level someone gave me. It has a laser that shines a line along the surface. Works fine in a darkened room, but is worthless in daylight. I never bother to use it.
