craftsman/skil 5.5" HD circular saw - noisy after cut
Forum topic by mikesdak posted 05-31-2018 12:05 AM 381 views 0 times favorited 3 replies Add to Favorites Watch
View mikesdak's profile
mikesdak
2 posts in 608 days
05-31-2018 12:05 AM
Hello.
I have a craftsman insdustrial type 5.5 inch saw. I believe it is the same saw as a Skil HD 5510, blade left saw. I like it, light weight and powerful enough to do the job. I bought it refurbished on Ebay about 15 years ago.
After making a cut, the saw sort of howls as it is winding to a stop. I’m guessing bad bearings or similar? Is this typical for a heavier duty style skil saw?
3 replies so far
View Loren's profile
10477 posts in 4259 days
#1 posted 05-31-2018 12:20 AM
If the blade coasts for a long time that can mean
the bearing lube has dried out. If you really
like the saw you might see about having it
serviced.
mikesdak
2 posts in 608 days
#2 posted 05-31-2018 12:49 AM
Thanks Loren. I ran it a little too see, and it coasts for about 3 to 4 seconds after letting go of the trigger. The noise isn’t real loud, just sounds like a bearing to me.
I checked the manual, and they say bearings should be replaced every other brush service.
I think it’s got two bearings. Is this something for an average diy person to do? Or should I go to the service center?
View johnstoneb's profile
johnstoneb
3131 posts in 2784 days
#3 posted 05-31-2018 01:16 AM
If you’re asking that question, you probably should take it to a service center.
-- Bruce, Boise, ID
