Machinable Waterproof Epoxy
Forum topic by Mosquito posted 05-30-2018 03:14 AM 828 views 0 times favorited 18 replies Add to Favorites Watch
View Mosquito's profile
Mosquito
10015 posts in 2903 days
05-30-2018 03:14 AM
I put this in finishing, but I’m not sure if it fits there or not. I’m rolling some ideas around in my head, and I’m wondering if anyone here knows of a good waterproof epoxy that’s relatively machinable with a router. I’m looking to fill a void with epoxy, and then machine a pocket out of it. I need it to be water proof as well. I’ve been sifting through various marine grade epoxies, but I thought I’d throw a post out here and see if anyone had some ideas.
Thanks for any suggestions!
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
18 replies so far
View bobasaurus's profile
bobasaurus
3618 posts in 3795 days
#1 posted 05-30-2018 03:39 AM
You’ll want a flexible epoxy of some kind, as most are so brittle they would probably crack somehow when contacting a router bit. This is the first thing I found on google, no idea if it’s good or bad:
https://theepoxyexperts.com/shop/casting-resins/max-cast-24-oz-epoxy-resin-super-flexible-tough-high-elongation-clear-casting/
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
bobasaurus
#2 posted 05-30-2018 03:40 AM
Though if it’s effectively cured urethane, it might be so rubbery it won’t cut either. Might have to experiment some.
Mosquito
#3 posted 05-30-2018 03:47 AM
I definitely plan to experiment some. It’s going to be some expensive experimentation lol It’s also possible that I could pour the epoxy around something else as well, to make the pocket, if I had to. Will have to figure that out as I try some things…
I’ll have some of this stuff left over from a current project, so I’ll probably start with that. It cures pretty hard, but says it should be machinable, so we’ll see…
MrUnix
7601 posts in 2810 days
#4 posted 05-30-2018 03:52 AM
Epoxy machines nicely, and in its neat form, is waterproof – it is commonly used as a barrier coat in marine applications. However, thick pours are problematic due to the heat generated. It would probably be better (and cheaper), if possible, to machine the ‘pocket’ first, then coat it with epoxy.
Mosquito
#5 posted 05-30-2018 04:02 AM
That is an idea Brad, thanks. The pocket was intended to be in the void to be filled with epoxy, but perhaps I could use something I can later remove or machine out to make the bulk of the pocket with out having to fill it all with epoxy first. Hadn’t thought of that.
The epoxy I’m using currently says to not pour more than 1/8” at a time, but through my experiments I’ve been able to pour up to about 1/4” fine, but that takes quite a while when it’s a few days between cures lol I know what you mean, though. First time I mixed a bit too much and left 3/4” in the bottom of the mixing cup, and yellowed while curing, presumably due to the excessive heat
View Lazyman's profile
Lazyman
4546 posts in 1998 days
#6 posted 05-30-2018 04:55 AM
Maybe a resin specifically designed for pouring or casting would be a better option than epoxy on this case? How big is the void?
View summerfi's profile
summerfi
4356 posts in 2298 days
#7 posted 05-30-2018 05:12 AM
If you coat a pocket-shaped object with wax, it will pull right out after the epoxy or resin has set. That’s assuming there are no flanges or other complicating shapes on it.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html -- ~Non multa sed multum~
View MikeB_UK's profile
MikeB_UK
151 posts in 1645 days
#8 posted 05-30-2018 08:31 AM
If you coat a pocket-shaped object with wax, it will pull right out after the epoxy or resin has set. That s assuming there are no flanges or other complicating shapes on it.
- summerfi
If it has any complicated shapes or flanges, cut the plug in pocket shape out of wax.
Pour the epoxy, push in the wax insert to the required depth (Inventive clamping may be required, may be easier to clamp first pour later).
When the epoxy is set you can just pull melt the wax plug out.
-- If I say I'll fix something around the house I will, there is no use nagging about it every 6 months.
View Dave Polaschek's profile
Dave Polaschek
4478 posts in 1193 days
#9 posted 05-30-2018 10:30 AM
The Max Clear Grade epoxy I have used for food grade stuff is machinable, as are most epoxies, but as others have said, it’ll be easier going if you don’t fill the void you want to cut out so that you minimize the machining needed. If you’d like to give it a try, I could bring it along when we get together for me to pick up the post drill from you.
-- Dave - Santa Fe
View John Smith's profile
John Smith
2135 posts in 773 days
#10 posted 05-30-2018 11:37 AM
CASTOLITE is just one of many companies that make casting and embedding resin
that is crystal clear for embedding things like artifacts, bugs, etc
and is easily machinable and stays clear forever. I have no idea how UV tolerant it is.
to broaden your education on this subject, google: “Casting and Embedding Resin”
http://www.castolite.com/
Castolite-AP Clear Casting Plastic
Castolite Formula AP is an Acrylic-Polyester resin; it is optically the clearest,
most light stable liquid plastic of this type.
Generates milder exothermic heat than other formulas
Excellent for embedding biological, mineral, or industrial components for display
Excellent for educational displays and visual teaching aids
-- I am a painter. That's what I do. I paint things --
Mosquito
#11 posted 05-30-2018 12:26 PM
Thanks so far everyone! Looks like I’ve got a few things to read up on, and think about. This is why I asked :-)
John Smith
#12 posted 05-30-2018 01:05 PM
I became familiar with Castolite Embedding Resin back in the early ‘80s
helping my daughter with her Girl Scout Troop embed items they had collected
into paperweights as gifts to their parents. I made a silicone mold and used Castolite resin.
a simple small vacuum chamber helps to relieve any bubbles that may form in the resin.
excellent project for anyone that has young kids or grandkids.
View ToddJB's profile
ToddJB
8583 posts in 2741 days
#13 posted 05-30-2018 03:08 PM
Is this in wood? Does it need to be pretty in color? Ive done what you’re describing with jbweld, but on cast products
-- I came - I sawed - I over-built
View MrRon's profile
MrRon
5813 posts in 3854 days
#14 posted 05-30-2018 07:45 PM
Smooth-on has a whole family of resins used for making castings. Get their informative catalog. Go WWW.smooth-on.com
Mosquito
#15 posted 05-30-2018 08:10 PM
Thanks Ron, Smooth-On was one of the brands I was looking at previously.
Todd, it would be in wood, yes. I’d like for it to be clear, for the effect I’m after
