I purchased this jointer used and I have noted that even with a 4" dust collection going I still get chips coming out the top of the jointer around, I think, the pulley that powers the cutter head. So far I have just used it on the narrow edge of boards and I need to clean up after each use. If I need it on the wide edge there would be quite a bit to clean up.
Anybody else had this problem and maybe solved it? Perhaps using a sheet of magnetic material cut to fit around the pulley area?
Any thoughts or ideas would be appreciated.
Thanks
Lecil Alexander
Thanks
Lecil Alexander
