sander marks
Forum topic by Karda posted 05-19-2018 10:35 PM 457 views 0 times favorited 7 replies Add to Favorites Watch
View Karda's profile
Karda
1967 posts in 1162 days
05-19-2018 10:35 PM
Hi, I have to paint some doors that were painted with rustoleums john deere green. Since it is a high gloss paint I will have to sand them but I don’t want to rotary. Thanks Mike sand because of marks. Will i have a sanding mark problem with a finishing sander, HF has one with a small triangular pad. I think it is orbital and a hi fine sand paper such as 150 or higher, The doors are metal
7 replies so far
woodbutcherbynight
6053 posts in 3017 days
#1 posted 05-20-2018 01:26 AM
Can you scuff them with steel wool, green or red scotchbrite pads?
Karda
#2 posted 05-20-2018 02:23 AM
yea I could do that but I am putting a flat paint over them and the green is a hi gloss. I went over some last year and didn’t Sand well enough, the gloss came through the new pit
View Kazooman's profile
Kazooman
1411 posts in 2561 days
#3 posted 05-20-2018 03:01 AM
I can’t offer a complete solution to your problem, but I do not think the small detail sander is what you are looking for. I have one (a Fein, not the HF) and it is great for many uses. It is not an orbital sander. The pad oscillates in a small arc around the pivot point of the shaft. Proof of this comes in the fact that you can fit these units with small circular (or semi-circular) saw blades. They do not move in an orbit, they just oscillate back and forth in a circular motion around the axis. As an aside, you can gently touch the saw blade and the natural give of your flesh prevents any cutting. Touch it with a firm piece of wood and it will cut into it.
I agree that you do not want to use a “rotary” sander (a pad mounted on a drill???). You probably want a true random orbit sander with some hand clean-up in hard to get at spots.
View MrUnix's profile
MrUnix
7598 posts in 2807 days
#4 posted 05-20-2018 03:08 AM
If you are sanding because you want adhesion of the new paint to the old gloss surface, have you considered using a paint deglosser instead? Much easier and can get into areas you can’t easily get to with sanding.
Karda
#5 posted 05-20-2018 03:49 AM
thanks for the warning on the sander, I’ll go the deglosser sounds like a better job thanks Mike
View corelz125's profile
corelz125
991 posts in 1585 days
#6 posted 05-20-2018 03:49 AM
Are you a hand plane user? If not you can use a paint stripper since you are only looking to take the gloss off you can use the less harsh ones. Peel away works good.
Karda
#7 posted 05-20-2018 03:52 AM
no plane, they are metal doors
