Picked up a 1960s Delta Unisaw model via auction for only $175
Forum topic by Medici posted 05-18-2018 09:32 PM 1857 views 0 times favorited 11 replies Add to Favorites Watch
View Medici's profile
Medici
50 posts in 1183 days
05-18-2018 09:32 PM
Topic tags/keywords: tablesaw finishing refurbishing milling
Just picked up this older model unisaw from a millwork shop in Yonkers, NY for only $175. The bidding started at only $25 via irsauctions, and I was going to go as high as $200. It’s got a 230v/460v, 3HP motor. It needs a bit of cleaning, and I didn’t get to see any internal pictures before I purchased it (since it was “as-is” from auction) but it still was being used in the shop, so I figured it can’t be that bad.
I disconnected the top when I got home, and to my surprise, it seemed to be in very good condition. No rust internally, just on the outside of the frame. I’m going to be checking the trunnions tomorrow morning. Luckily, being a finishing carpenter at a manufacturing company, I’ll be able to bring it into our shop on my free time, sand it all down, and professionally respray the body. I’ll also sand down the small surface rust on the cast iron top. The only I am going to change on it, is add a new switch, since this one is almost striped out. An electrician friend of mine is going to help me install a modern, Grizzly style 230v paddle switch. Unfortunately, until I move this summer, I won’t have a 230v outlet to plug it in.
I’ll eventually be posting a full re-finishing job of the saw with plenty of pictures, but for once, I wanted to flaunt something, instead of just ask questions from all you guys. :P
11 replies so far
View MrUnix's profile
MrUnix
7578 posts in 2800 days
#1 posted 05-18-2018 09:46 PM
Nice get. Is that a “DH” serial number? If so, that makes it a 1965 model. Only thing I would suggest is to not use any abrasives on the top (ie: sandpaper). Start with a razor blade to scrape most of the crap off, then hit it with a scotch brite pad and some kind of solvent. Placed under a vibrating sander makes it easier. If you still have some staining, oxalic acid (eg: barkeepers friend) will usually take care of that. Then just keep it good and waxed.
Also, according to the 1965 catalog, they didn’t offer a 3hp motor – so if that is what yours has, it had to have been special ordered. Stock configuration was 1.5hp (single phase) or 2hp (3-phase).
View tomd's profile
tomd
2216 posts in 4372 days
#2 posted 05-18-2018 09:58 PM
Nice find, great buy. Have fun refurbishing it.
-- Tom D
View TheFridge's profile
TheFridge
10859 posts in 2087 days
#3 posted 05-18-2018 09:59 PM
Welcome :) nice haul. Working on a couple restos myself.
I’d like to echo brads comment about sanding. I wouldn’t recommend it. A razor scraper and a dozen blades will take off more rust than you could imagine.
Medici
#4 posted 05-18-2018 11:05 PM
Also, according to the 1965 catalog, they didn t offer a 3hp motor – so if that is what yours has, it had to have been special ordered. Stock configuration was 1.5hp (single phase) or 2hp (3-phase).
- MrUnix
It is a DH model! Thanks for all that info, that’s more than I have found myself. I’ll do more diggin around tomorrow. Did Rockwell offer a 3hp special order model? Or were they 3rd party?
MrUnix
#5 posted 05-18-2018 11:13 PM
You can look at the 1965 catalog here: Delta Industrial Machines Catalog AB-65, Scan Part 2
(Part 1 is mostly just drill presses)
AFAIK, there were no third party suppliers for the Unisaw motors as they required a special mount. I did a quick scan and I don’t see a 3hp listed in 1965, but that doesn’t mean they didn’t offer them, and – there is no telling what a PO may have done over the years to that machine – it could be a newer motor mounted in there. Post a picture of the data plate.
View greenacres2's profile
greenacres2
343 posts in 2769 days
#6 posted 05-19-2018 01:06 AM
Based on the “230V/460V” comment, i’m guessing 3ph (3 phase), which you may be confusing with 3hp. That said, even buying a phase converter so you can run on 1ph it’s still a good buy.
Earl
Medici
#7 posted 05-19-2018 01:12 AM
Based on the “230V/460V” comment, i m guessing 3ph (3 phase), which you may be confusing with 3hp. That said, even buying a phase converter so you can run on 1ph it s still a good buy.
Earl
- greenacres2
Yes sorry! Wow sorry, didnt even notice I went on like this. Yes its 3 phase. I was literally looking up inverters when I re-read this.
MrUnix
#8 posted 05-19-2018 01:33 AM
- Medici
Well, that explains a lot :)
Figure another $300 to get it up and running… less than $200 for a VFD, and another hundred or so for bearings, belts, a blade and maybe some new wire.
View Gene Howe's profile
Gene Howe
11994 posts in 4030 days
#9 posted 05-19-2018 02:46 AM
Even I f you have to spend another $200 or so, you still suck. Great find. Great buy.
Medici
#10 posted 05-19-2018 06:46 PM
- Gene Howe
Thanks haha!
View knotscott's profile
knotscott
8351 posts in 3977 days
#11 posted 05-19-2018 08:27 PM
Great buy! Congrats!
