Forum topic by wjt99 | posted 05-15-2018 02:47 AM | 1872 views | 0 times favorited | 2 replies | ![]() |
I was asked to look at a Bosch 5412L crosscut miter saw which had a blade guard that was not retracting smoothly. The operator had to manually get it started the first couple of inches. A dangerous situation especially since it was used in a school shop. I found a few references on the web to this problem with no clear solutions. After some tinkering I came up with this idea. I attached a 1.25” O.D. flat washer using aluminum pop rivets to the linkage at the point where it was hanging up on the bearing. This change resulted in a smoother transition across the arm and the guard now retracts easily. I added a pair of flat washers behind the bearing so it is centered on the linkage and 1.25” washer. Bill |
