Getting a straight fence for cross cut sled
Forum topic by Lookwow posted 05-14-2018 04:05 PM 1872 views 0 times favorited 4 replies Add to Favorites Watch
View Lookwow's profile
Lookwow
11 posts in 622 days
05-14-2018 04:05 PM
So I have tried several times using multiple pieces of 3/4 in plywood to get a straight fence without bow/warp and every time I end up with some amount. Maybe not right away but over 4 months or so it warps some.
I’ve been debating between doing a one miter slot sled with some extruded aluminum or getting a after market miter gauge.
Any tips on getting and keeping a straight fence or what you would do.
View Loren's profile
10477 posts in 4256 days
#1 posted 05-14-2018 04:28 PM
I had one where I used a piece of angle iron
with a board bolted to it and shims in between
to square it. Both steel and aluminum angle
are quite straight generally.
MDF or melamine may stay straighter than
plywood in this application. Plywood still
has intact wood cells in it that absorb moisture
through the exposed end grain and may
“wave” with fluctuations in ambient humidity.
I don’t know why plywood does this really,
but it’s definitely not a material that can be
relied on to stay dead flat if it isn’t fastened
down or evenly supported.
View Robert's profile
Robert
3602 posts in 2089 days
#2 posted 05-14-2018 06:52 PM
Screw vertical fence to the factory edge of plywood and add a few 90° braces. Screw this assembly to sled base.
Screw one end tight and then do your 90° adjustment.
Try using AZAK for runners. Lotsa screws/best with a shallow dado.
View bbain32's profile
bbain32
34 posts in 1783 days
#3 posted 05-29-2018 02:09 PM
I made the fence for my main crosscut sled by laminating 3 pieces of 1/2” plywood together.
When I did the glueup I clamped it down to the top of the tablesaw (with wax paper in between) as it is the largest flattest surface in my shop. it seems to have stayed true enough for my purposes.
View jonah's profile
jonah
2092 posts in 3907 days
#4 posted 05-29-2018 02:18 PM
Look at using aluminum extrusions. They’re dead flat (or close enough for our purposes, anyway), and you can get them delivered to a Grainger store for free. You’ll spend maybe $30, but you get a very flexible, easily adjusted fence that is definitely dead flat and will stay that way.
