DeWalt 735
Forum topic by Gerald Thompson posted 05-12-2018 05:49 PM 492 views 0 times favorited 2 replies Add to Favorites Watch
Gerald Thompson
1234 posts in 2845 days
05-12-2018 05:49 PM
Any ideas why I cannot raise the planer higher than around 4’’? i have not used it in about 8 months and I just ran some lumber to 3/4’’ thickness. When I crank it up it gets tighter from about 3.5’’ and will stop just proud of 4’’.
-- Jerry
2 replies so far
View Bill White's profile
Bill White
5242 posts in 4571 days
#1 posted 05-12-2018 06:01 PM
You’ve got some junk, chips, etc. blocking your elevation mechanism. Check the internals. Don’t force anything until you’ve checked.
-- [email protected]
Gerald Thompson
#2 posted 05-12-2018 08:20 PM
I looked inside and took off the blade shroud and saw nothing that could be causing the problem. I will check the four threaded posts on the corners tomorrow and see if one or more has junk in the threads.
If that fails I will have to drag out the jointer for pieces over 4 inches tall for quick joinery.
-- Jerry
