Simple Breakfast Table with Hairpin Legs--need reinforcement?
Forum topic by CharlesA posted 05-10-2018 01:35 PM 1161 views 0 times favorited 5 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3393 posts in 2399 days
05-10-2018 01:35 PM
I’m finally making something 7 months after we decided to move. I don’t have my shop quite together, but I’m anxious to get going.
I’m making a 48” round breakfast table out of some 5/4 cherry I have. I’m attaching hairpin legs to get this thing done quickly.
I’m doing a basic glue-up. I’m not planning on doing any reinforcing of the table top (should end up 7/8” of an inch thick or so). Would you do any reinforcement on the bottom surface of the table?
It will look something like this:
Thanks, Charles
5 replies so far
View Sludgeguy's profile
Sludgeguy
57 posts in 723 days
#1 posted 05-10-2018 02:11 PM
It should be fine with a good glue-up.
View Lazyman's profile
Lazyman
4469 posts in 1988 days
#2 posted 05-10-2018 02:35 PM
I have never used them but with hairpin legs long enough for a breakfast table I would worry that with screws only into the top about 3/4” they could be pulled out if force was applied just right (or wrong).
CharlesA
#3 posted 05-10-2018 03:05 PM
Worth thinking about, Nathan. Any thoughts on mitigating that risk?
Lazyman
#4 posted 05-10-2018 04:00 PM
Perhaps attaching 3/4” thick blocks or strips to the bottom with glue and/or screws would allow you to double the depth of the screws that attach the legs. If you use strips either in an X or square that would also add a little more rigidity to the top as well. If you are concerned about how that would appear from a distance, perhaps a plywood disc or ring painted or stained a similar color would look better.
CharlesA
#5 posted 05-10-2018 05:38 PM
the folks at tablelegs.com suggest cleats:
