Can I use HVLP for BLO?
Forum topic by LiveEdge posted 05-08-2018 10:40 PM 824 views 0 times favorited 9 replies Add to Favorites Watch
View LiveEdge's profile
LiveEdge
600 posts in 2228 days
05-08-2018 10:40 PM
I’ve always wiped on boiled linseed oil, but I have a project with lots of nooks and crannies and wondered if spraying very light applications would work? First, I wanted to make sure it would be suitable for spraying? Second, I wanted to know if I could get the coat light enough that I wouldn’t have to wipe off excess as that will be as hard as putting it on.
Thoughts?
9 replies so far
View Rich's profile (online now)
Rich
5146 posts in 1197 days
#1 posted 05-08-2018 11:54 PM
Yes to both. Assuming you have a good spray setup, and can dial back the flow sufficiently you can do light dusting coats and build until you get the amount you want.
I see two issues though, one if you’re getting into nooks and crannies, then as you spray around and into those areas, you will likely get a thicker buildup that will require some wiping. I think it’s more realistic to expect to have to do a fair amount of wiping anyway. I do see spraying initially as a timesaver in uneven areas.
View John Smith's profile
John Smith
2135 posts in 771 days
#2 posted 05-09-2018 01:34 AM
you have not said how big your project is or offered up any photos,
but, for me, I would skip the HVLP and break out the automotive touch-up gun ($13.00 @ HF)
for the detail work then when that is satisfactory, I would get the rest with the HVLP.
of course this depends on your shop setup and choice of application methods.
you may think it is “Old School” ~ but, that is just me.
-- I am a painter. That's what I do. I paint things --
Rich
#3 posted 05-09-2018 01:47 AM
- John Smith
Why?
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#4 posted 05-09-2018 01:47 AM
You’ll still have to wipe.
John Smith
#5 posted 05-09-2018 02:36 AM
Rich – I have had two HVLP sprayers in the past and for some reason,
I could not focus down to the fine detail spray that I needed for the intracate areas.
so I either used the air brush or automotive touch-up gun and the HVLP for larger areas.
(could it be my patience level ??).
Rich
#6 posted 05-09-2018 04:13 AM
- John Smith
Those guns typically have 0.5 to 0.8mm projector sets. Do you think that’s adequate for oil?
Edit: Never mind. It appears that gun has a 1.5mm nozzle (touch up?...lol). Nonetheless, I’ll stick with my Fuji Q4. It’s done the job for me for almost 20 years.
LiveEdge
#7 posted 05-09-2018 03:59 PM
The project is a large model maybe 2’x3’. I’m not to the place to finish yet, but it’s coming in the next weeks. I think I’ll do some testing to see how light I can get it and how much wiping I need to do. Thanks for the advice. The project will hopefully be posted within a month. :)
View Kelly's profile
Kelly
2637 posts in 3552 days
#8 posted 05-10-2018 06:43 AM
My 4 state CapSpray is a touch up gun, depending on the tip I use. Even with a latex tip, it’ll get down to just above an airbrush.
- John Smith
Kelly
#9 posted 05-10-2018 06:45 AM
As to getting build up in corners, I’ve never done a BLO finish I didn’t have to wipe down, since it’s impossible to guess how much oil the project will absorb, and any excess must be wiped off to avoid orange peel.
