FOREDOM flex shaft, oil?
« back to Woodcarving forum
Forum topic by BlasterStumps posted 05-07-2018 11:28 PM 1171 views 0 times favorited 13 replies Add to Favorites Watch
View BlasterStumps's profile
BlasterStumps
1496 posts in 1048 days
05-07-2018 11:28 PM
I found this Foredom flex shaft at a local Restore. I don’t know much about it except it seems to turn okay. I’m wondering though if they require any periodic oiling in the shaft part? Anyone care to share their knowledge of lubricating one.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
13 replies so far
MrUnix
7597 posts in 2807 days
#1 posted 05-08-2018 01:58 AM
The manual says to clean and grease the shaft after 50 hours of use.
View Jim Jakosh's profile
Jim Jakosh
23765 posts in 3713 days
#2 posted 05-08-2018 02:14 AM
I’m thinking graphite would be the best for that. I think the inner flex wire comes out and can be coated with graphite and slipped back in. I use that on my Harbor Freight hanging power carver.
Jim
BlasterStumps
#3 posted 05-08-2018 03:08 AM
Thanks guys. I will get some lube for it and give it a try. I can hook it to either my old Dremel or my cordless drill for now. I’ll have to experiment with it. I only have some old Dremel bits at this point.
Thanks again. And Thanks Brad for the link to the manual.
Mike
View Redoak49's profile
Redoak49
4355 posts in 2597 days
#4 posted 05-08-2018 11:10 AM
A quick trip with Google to find the manual provides maintenance info. They recommend a white grease.
View mpounders's profile
mpounders
946 posts in 3503 days
#5 posted 05-08-2018 09:09 PM
It’s best not to store it coiled up. It can develop kinks and cause the shaft to wear out quicker than it should. Hanging it pr laying it straight is preferred.
-- Mike P., Arkansas, http://mikepounders.weebly.com
BlasterStumps
#6 posted 05-09-2018 12:29 AM
It s best not to store it coiled up. It can develop kinks and cause the shaft to wear out quicker than it should. Hanging it pr laying it straight is preferred.
- mpounders
Great to know that. Thank you! I will fix a hanging storage for it. It only cost me $5. I felt very lucky to find it. You wouldn’t believe how long I have wanted a flex shaft in the shop. I plan to take care of it. I may even look into a hammer handpiece and some carving tools. So fun (I think). I’m going to be keeping an eye out for a used FOREDOM benchtop lathe to power it and to use as a buffer.
Thanks again,
Mike
Mike
View Clarkswoodworking's profile
Clarkswoodworking
289 posts in 742 days
#7 posted 05-09-2018 02:58 PM
That shaft will fit this machine
https://m.harborfreight.com/flexible-shaft-grinder-and-carver-40432.html
I have one it works great
Scott
BlasterStumps
#8 posted 05-09-2018 05:01 PM
Scott
Thank you Scott! I will be in HF in the near future and will look into it. Might have to save some mad-money first. : )
- Clarkswoodworking
View mel52's profile
mel52
1205 posts in 873 days
#9 posted 05-09-2018 11:45 PM
If you hang it up to keep it straight and out of the way, Like I do mine, you might want to cover the end with a piece of material or paper towel using a rubber band, etc. When using it the shaft will get warm which in turn warms the lubricant and makes it softer ( runnier, if this is a word ) and it may drip at the end or just set their until touched with something. It isn’t much, but is annoying to get on hands, clothes, or in my case a piece of wood. This has rarely happened, but I don’t take any chances now. By the way, this happened with the manufactures lubricant in it while still new.
-- MEL, Kansas
BlasterStumps
#10 posted 05-10-2018 03:38 AM
If you hang it up to keep it straight and out of the way, Like I do mine, you might want to cover the end with a piece of material or paper towel using a rubber band, etc. When using it the shaft will get warm which in turn warms the lubricant and makes it softer ( runnier, if this is a word ) and it may drip at the end or just set their until touched with something. It isn t much, but is annoying to get on hands, clothes, or in my case a piece of wood. This has rarely happened, but I don t take any chances now. By the way, this happened with the manufactures lubricant in it while still new.
- mel52
I did hang it but may find a place where I can lay it down flat. Thanks for the advice. I was looking at the Foredom lube and see it is about $7. Not too bad but I imagine there are other lubes that will work too. When I get back into the city, I will search around to see what I can find.
Mike
View ClaudeF's profile
ClaudeF
1057 posts in 2315 days
#11 posted 05-10-2018 02:34 PM
Make sure the lubricant you get says it is good for high speeds – not all are…
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
BlasterStumps
#12 posted 05-10-2018 09:11 PM
I will Claude, thank you.
Mike
View TheFridge's profile
TheFridge
10859 posts in 2094 days
#13 posted 05-11-2018 12:05 AM
A little lubricant on the shaft goes a long way.
