Miter saw blade....Cmt, Freud or something else
Forum topic by Don Newton posted 05-07-2018 12:42 AM 1568 views 0 times favorited 10 replies Add to Favorites Watch
View Don Newton's profile
Don Newton
725 posts in 4227 days
05-07-2018 12:42 AM
Looking to upgrade the blade on my DeWalt miter saw. Was considering CMT or Freud. Any suggestions?
-- Don, Pittsburgh
10 replies so far
View msinc's profile
msinc
567 posts in 1112 days
#1 posted 05-07-2018 06:07 AM
I don’t know of any “bad” blades….they are all good and will make nice clean cuts, especially when new. What I have found is that it is a good idea to keep the old blade for use on the rough stuff and buy a new one for when you really need to be accurate. I know it is a pain to change blades, but it pays off in the long run. I have two “old” used blades that I put on my saw if I am just cutting wood that really don’t matter…e.g. rough cut lumber I want to square one end on before I stack it to dry. I keep a nice blade for clean accurate miters and such when I am trying to be real accurate and want a nice smooth cut. I have found that the DeWalt blades are just about as good as any if you take good care of them. That said, Amana Tool makes one of the best. I will say one more thing…..when I am making a picture frame I cut the final miters with a miter trimmer.
5929 posts in 3101 days
#2 posted 05-07-2018 10:46 AM
I think the type of blade (tooth count, hook angle, etc) is more important than the exact brand. All that has to be considered along with what kind of work you expect to do with the saw. Mine is for construction use only and I have an aggressive cutting CMT blade on it. But if I was doing picture frames or crown molding, I get something that cut much more smoothly, maybe a negative hook blade.
View Andybb's profile
Andybb
2378 posts in 1212 days
#3 posted 05-07-2018 04:43 PM
I keep an 80 tooth on my miter saw. Brand doesn’t seem to matter. Last one was on there for 6 years. Only changed it cuz it seemed like it was time. Put a CMT on that I got from Amazon. I keep the old blade around for when I need an 80 tooth for the table saw. When you think about it they really don’t see that much use as they usually only run for 10-15 seconds at a time.
-- Andy - Seattle USA
View Gene Howe's profile
Gene Howe
12002 posts in 4037 days
#4 posted 05-07-2018 05:03 PM
I use 60 and an 80 tooth Tenryu Miter Pro. Very satisfied.
View mel52's profile
mel52
1205 posts in 873 days
#5 posted 05-07-2018 06:38 PM
On my Dewalt table saw I use the Dewalt ripping ( so far ) blade that came with it. I bought a few Diablo blades in different tooth counts for everything else. Their thin kerf doesn’t seem to take as much power to cut. Just my opinion.
-- MEL, Kansas
View Sludgeguy's profile
Sludgeguy
57 posts in 731 days
#6 posted 05-07-2018 07:04 PM
Forrest are very nice but they are pricey.
View josephf's profile
josephf
217 posts in 2705 days
#7 posted 05-07-2018 07:43 PM
you really need to say how and what your using it for .my forest blade cuts trim with zero chipping ,perfect edge .but will not cut that prefinished flooring for very long .I think frued is over priced for the quality .My experince with frued thin kerf is they do not take much to deflect ,dull faster then others . Tenryu makes great blades, Amana has great blades .And Cmt has plenty to choose from . Are CMT general less in price then Amana and Tenru ??? I do or did have a CMT for trim .resharpened it a few times . Wait had two ,one was better in my nonslider then the other .
So main thing is get the blade that fits what you cutting . I have “cheap” blades also .But that dewalt blade that came with my new saw is seriously lacking in the “Nice cutting ” department .i will use up on some treated wood or used/recycled wood .
View Richard's profile
Richard
11309 posts in 3641 days
#8 posted 05-07-2018 07:46 PM
- Fred Hargis
I agree with Fred. The “Use” It’s intended for is the most important Aspect.
Rick
-- Richard (Ontario, CANADA)
View knotscott's profile
knotscott
8364 posts in 3984 days
#9 posted 05-07-2018 08:49 PM
CMT Industrial and Freud Industrial are both solid choices. I’d add Infinity, Ridge Carbide, Tenryu, Forrest, and Amana Tool to the list. As mentioned, getting the right blade for the task is as important as the brand….depending on the task – typically 60T to 80T, Hi-ATB or ATB grind for least tearout, a triple chip grind (TCG) for tough brittle materials and longest edge life, or even a combination ATB/R for versatility and good edge life.
View darthford's profile
darthford
612 posts in 2532 days
#10 posted 05-09-2018 01:31 PM
I run a Ridge Carbide 12” RS1000 Ultra Blade, 80 Tooth on my Bosch GCM12SD
