Quick Tip For Anyone Struggling With Coating on Stanley Sweetheart Chisels
« back to Hand Tools forum
Forum topic by toolingfooling posted 05-06-2018 06:41 PM 689 views 0 times favorited 5 replies Add to Favorites Watch
View toolingfooling's profile
toolingfooling
5 posts in 637 days
05-06-2018 06:41 PM
Topic tags/keywords: tip trick
I recently acquired a set of Stanley Sweetheart Chisels, new in box from 2016 at a local sale. I read a bunch of horror stories about removing the epoxy like coating on these that some people referred to as laquer. I, too, tried the standard laquer thinner with MEK and Acetone, no dice. Considering it might be something different from laquer, more along the lines of epoxy lead me to soak them for 5 minutes in a $0.99 bottle of isopropyl alcohol, 99% (strong rubbing alcohol from Walmart pharmacy). Pulled them out, wetted a scotch brite pad with more alcohol, and the coating came off so easily, it was child’s play. I’ve seen so many threads with people struggling with this coating that I just thought I’d share and hopefully make someone’s day easier.
Jarod
5 replies so far
View Andre's profile
Andre
3017 posts in 2415 days
#1 posted 05-06-2018 06:57 PM
I just wiped mine down with mineral spirits on a rag, worked great ?
View joey502's profile
joey502
558 posts in 2127 days
#2 posted 05-07-2018 01:01 AM
I soaked the ends of mine in lacquer thinner and it came right off.
View TheFridge's profile
TheFridge
10859 posts in 2095 days
#3 posted 05-07-2018 01:28 AM
I used hydroponic acid.
View MrRon's profile
MrRon
5812 posts in 3853 days
#4 posted 05-07-2018 05:41 PM
- TheFridge
I used Sulphuric acid, but left it too long; they dissolved. Only joking.
View jimintx's profile
jimintx
934 posts in 2194 days
#5 posted 05-07-2018 06:20 PM
I didn’t know you needed to remove it…
-- Jim, Houston, TX
