Waiting Time
Forum topic by Sludgeguy posted 05-05-2018 02:00 AM 1064 views 0 times favorited 27 replies Add to Favorites Watch
View Sludgeguy's profile
Sludgeguy
57 posts in 733 days
05-05-2018 02:00 AM
How long do you guys wait after gluing up a panel before sanding or planing? I understand that the wood swells a tiny bit at the joints due to the moisture in the glue so it’s good to let it dry to prevent depressions in the finished surface. I’ve been waiting a week and it seems to provide good results but I was wondering if I could speed things up.
Thanks
27 replies so far
View Loren's profile
10477 posts in 4259 days
#1 posted 05-05-2018 02:11 AM
Well, it does depend to some extent on the type
of glue, humidity and temperature but I’ve found
overnight is adequate.
Mostly the problem people have had with this has
to do with biscuit joints. That’s another reason
not to use them for aligning edge joints, which is
something that Norm Abrams would do I think,
so some folks picked up the habit and had problems
with biscuit-shaped depressions after sanding too
soon.
View sawdustjunkie's profile
sawdustjunkie
408 posts in 2328 days
#2 posted 05-05-2018 02:13 AM
I only wait overnight for a glue up. Then sand or plain to the size I need. Waiting a week is a waste of time for me.
-- Steve: Franklin, WI
View Woodknack's profile
Woodknack
13026 posts in 2991 days
#3 posted 05-05-2018 02:16 AM
Overnight/next day.
Biscuits are no problem for me. I have only ever seen one example of a “biscuit divet” and that was posted a few months ago by jbay, prior to that I thought they were a myth. I suspect it happens when someone puts the biscuit near the surface instead of in the middle where it should be.
Sludgeguy
#4 posted 05-05-2018 02:18 AM
I use 1/4” splines with tite bond. Seems like a couple days in a hot Florida garage should be OK. Thanks for the replies
View johnstoneb's profile
johnstoneb
3131 posts in 2783 days
#5 posted 05-05-2018 02:26 AM
I like to wait overnight before applying any stress to a glue joint. Waiting a week is completely unnecessary
-- Bruce, Boise, ID
View mudflap4869's profile
mudflap4869
2008 posts in 2070 days
#6 posted 05-05-2018 02:39 AM
4-6 hours if the weather is warm and dry, overnight for any other weather. I RARELY glue when it below 40 degrees.
-- Still trying to master kindling making
woodbutcherbynight
6054 posts in 3020 days
#7 posted 05-05-2018 03:36 AM
Overnight, because I have to go to work and have yet to perfect cloning myself to send clone to work and leave me to be in shop all day.
LOL
View Rich's profile
Rich
5156 posts in 1200 days
#8 posted 05-05-2018 04:55 AM
I think a more critical time is when do you start to clean the squeeze out. Do you sponge it off immediately and risk contaminating the area around it, or do you wait a while and hit it with a chisel plane (my technique), or do you wait and sand it?
woodbutcherbynight
#9 posted 05-05-2018 05:01 AM
I use a spoon to remove bulk then chisel out once dry. Problem is I am sometimes messy and that is how I have glued the wrong things together. LOL
View Rich's profile
Rich
#10 posted 05-05-2018 05:07 AM
- woodbutcherbynight
A spoon? I think we need to resurrect the “Without Personal Experience” thread.
Seriously though, what’s your spoon technique?
View AlaskaGuy's profile
AlaskaGuy
5523 posts in 2920 days
#11 posted 05-05-2018 07:33 AM
This should raise some eyebrows but it’s true and I never had a problem. I have run plenty of cabinet door sized glued up panels after 30 minutes clamp time. I don’t work in my shop unless it 70 degrees or more. I have learned not to use to much glue so my squeeze out doesn’t run all over the place. Pull them out of the clamps at 30 minutes, run a chisels down the joints to remove excess glue and take a pass in the planer to bring to finial size.
View JohnDi's profile
JohnDi
80 posts in 2044 days
#12 posted 05-05-2018 09:15 AM
I wait overnight and have never had a problem.
View EarlS's profile
EarlS
3434 posts in 2959 days
#13 posted 05-05-2018 10:53 AM
I use titebond and gorilla glue. I always let them sit over night. Generally I either have other things to work on, or it’s time to quit for the day.
I’ll use a damp rag to clean off the squeeze out on titebond immediately after I get the clamps on tight. I’ve never had problems with the water diluting the glue in the joint since the joint is tight and the water is only on the rag and the surface of the board. If I don’t get it wiped off, then the squeeze out is sanded off when the glue line is sanded smooth and flush. You can tell when titebond is cured as it becomes very hard.
For Gorilla glue (polyurethane) I wait for it to foam out and then scrape off the excess with a piece of scrap. After it dries you can cut it with a knife (inside corners), scrape it, use a chisel, or sand it down. Cured gorilla glue is still a bit spongy due to the entrained air. The top usually gets a crust on it as it cures but it isn’t sticky when it is cured.
View John Smith's profile
John Smith
2135 posts in 773 days
#14 posted 05-05-2018 06:58 PM
I agree with Rich on waiting for the excess to dry then cut it off.
one note that bears mentioning is epoxy – I always wait double the cure time
for “thickened” epoxy as I have had a few failures when pushing the cure time.
so with this thread, all adhesives should be covered.
as for foaming urethane, if it warrants, I mask off each adjoining surface so the excess does not stick
to the surrounding areas – unless the whole panel is going to be sanded down after.
as for Gorilla Glue (foaming) ~ if you are experiencing a spongy middle after curing, it is not due to the
entrained (entrapped) air – it is from the wood not being wet enough during application.
expanding urethane glue cures with moisture, not air. not enough moisture = uncured adhesive. (IMHO).
[get some scrap wood, wet it good, apply the glue, and you will see the difference]
and ~ what’s with the “spoon” ??
-- I am a painter. That's what I do. I paint things --
View cabmaker's profile
cabmaker
1745 posts in 3420 days
#15 posted 05-05-2018 08:28 PM
3-4 hours
