Mission or Arts & Crafts Square Buttons
Forum topic by adot45 posted 05-04-2018 02:35 PM 1152 views 0 times favorited 14 replies Add to Favorites Watch
View adot45's profile
adot45
165 posts in 1231 days
05-04-2018 02:35 PM
Hello, not sure this is the right forum for this question but I’m trying to find out how to make those square decorations that are common on these type of projects. Are they appliques or the ends of tenons? but how to make the triangles.
Thank You
-- David -- sent from my linux box
14 replies so far
View Dave Polaschek's profile
Dave Polaschek
4454 posts in 1189 days
#1 posted 05-04-2018 02:53 PM
If you’re talking the bits that look like little pyramids, they’re typically inserts or the ends of pegs in the pieces I’ve seen. Make them by running a block plane over the four edges of a rectangular post and basically chamfering the corners until the four chamfers meet in a point, if that makes sense.
-- Dave - Santa Fe
View jmartel's profile
jmartel
8696 posts in 2757 days
#2 posted 05-04-2018 02:54 PM
They can be applied, or on the ends of tenons. Just depends on the level of work you want to do. You can also make a table saw jig for them if you don’t want to use a block plane.
adot45
#3 posted 05-04-2018 03:08 PM
Thank You both, those are two good ways I’d feel comfortable with trying.
View bbasiaga's profile
bbasiaga
1243 posts in 2602 days
#4 posted 05-04-2018 03:56 PM
I think if you sort through the Samaurai Carpenter channel on YouTube he has a video about making them. Or alt least he has made them a bunch of times in his videos.
Brian
adot45
#5 posted 05-04-2018 04:05 PM
I will check that out Brian, thanks.
View theart's profile
theart
154 posts in 1161 days
#6 posted 05-04-2018 05:31 PM
Rockler makes them to fit a 3/8” round countersink:
http://www.rockler.com/craftsman-pyramid-top-hole-plugs-oak-12-pack
Pricey if you need a lot of them though.
View splintergroup's profile
splintergroup
3207 posts in 1829 days
#7 posted 05-04-2018 09:09 PM
I made the pyramid plugs for some picture frames in my projects section.
They are easy to mass produce on a table saw, basically you start with a section of square stock (3/8”x3/8”), use a stop block on a miter gauge to cut the end chamfers (maybe try the blade tipped to 30 degrees), then cut a tenon around the base such that the plug can fit directly into a 5/16” drilled (round) hole. A round hole is much easier then a square one 8^)
This shows the basic steps for some “pillowed” style I used in another project:
just missing the chamfers.
adot45
#8 posted 05-04-2018 09:53 PM
Thanks gents, I’ll give making them a shot and if it doesn’t work out, I’ll go to rocker a nd get some.
View JohnDi's profile
JohnDi
80 posts in 2040 days
#9 posted 05-04-2018 09:58 PM
William Ng has a good video on YouTube showing how he makes his.
adot45
#10 posted 05-08-2018 09:21 PM
Well, turns out I was way too worried about making these, and I appreciated all the help.
I just took four pieces of stock, squared them up and set a stop block up on my miter saw and cut them. I did 40 degrees for the look I wanted on little uprights and 30* for the applique type. Don’t know if it matters but I cut a side then turned it 180 and cut the opposing side then 90 etc.
The wood is spalted white oak.
View Woodbum's profile
Woodbum
902 posts in 3672 days
#11 posted 05-09-2018 09:23 AM
Check out Darryl Peart’s books on Greene and Greene furniture for info on the ebony pillowed plugs. Also William Ng’s website has some info on the Greene and Greene style plugs. These are not pyramids, but pillow top plugs with very well defined shoulders that sit proud of the surrounding surface by approx 1/64” +/-. Work safely, have fun and Good luck!
-- "Now I'm just another old guy wearing funny clothes"
View EarlS's profile
EarlS
3427 posts in 2955 days
#12 posted 05-09-2018 11:36 AM
Those are going to be some seriously cool looking pyramid plugs. Can’t wait to see that project.
I used a similar approach to what Splinter mentioned to make pyramid plugs with the recessed tenon.
The G&G pillow plugs that Darelll Peart and William Ng describe are made by rounding over a “pillow” on the end of the square rod, then cutting the rod off to make the plug. The plug is tapered slightly using a chisel then driven into the square hole, and left slightly proud of the wood as previously mentioned.
IMO – The pillow plugs are easier to make.
adot45
#13 posted 05-09-2018 02:18 PM
Those are going to be some seriously cool looking pyramid plugs. Can t wait to see that project.
- EarlS
EarlS, Here’s a little teaser for you.
Even though this is just my “practice one” I’m going to write it up as a project and post it.
Only the posts in this project, the “plugs” are for the other project I have going.
adot45
#14 posted 05-10-2018 01:03 PM
Got my little project finished and it turned out OK.
It is a coal mine canary cage.
http://lumberjocks.com/projects/377993
