Cutting board maintenance
Forum topic by becikeja posted 05-04-2018 11:50 AM 726 views 0 times favorited 11 replies Add to Favorites Watch
View becikeja's profile
becikeja
1045 posts in 3423 days
05-04-2018 11:50 AM
Several months back, I took a run at making a couple of cutting boards. They came out great and have been used to full potential. Now it’s obvious they need to be refinished. The original finish was mineral oil then finished with a butcher block wax oil mixture. My question is, do I need to sand these to get all the wax oil mixture off, or do I simply add a new coat of the wax oil mixture, or do I go all the way back and soak with mineral oil and repeat the entire process?
11 replies so far
View TimInIndiana's profile
TimInIndiana
153 posts in 750 days
#1 posted 05-04-2018 11:52 AM
I just recondition them with the wax/oil paste. Rub it on thick, let it sit for an hour or so, then polish it off.
View EricTwice's profile
EricTwice
248 posts in 1143 days
#2 posted 05-04-2018 11:55 AM
clean them well, and add more of your oil and wax mixture
-- nice recovery, They should pay extra for that mistake, Eric E.
View ChefHDAN's profile
ChefHDAN
1499 posts in 3459 days
#3 posted 05-04-2018 12:43 PM
If you’re going to use them, don’t get too worried with the finish, its something that has to be regularly maintained. Regularly scrub it with soap & water to clean and sanitize rinse well and then wipe dry. Leave it it an area with good circulation to fully air dry, I put mine on the stove top grates so it can air on both sides. When it begins looking dry and the work areas are clearly visible I pour block oil onto it and just use a bare hand to work the oil evenly over the top and leave it to soak for a few hours. End grain boards take much longer to need sanding than long grain boards. My end grain board lives on the kitchen island and gets used daily, I have sanded it out twice in the last 20 years. My long grain butcher block tables though, maybe every 5 years.
View CRAIGCLICK's profile
CRAIGCLICK
117 posts in 683 days
#4 posted 05-04-2018 01:55 PM
The best finish for a butcher block is hog fat…at least it is at the Skylight Inn.
That’s not wear…it’s history, my friend!
-- Somewhere between raising hell and amazing grace.
View mel52's profile
mel52
1211 posts in 874 days
#5 posted 05-04-2018 02:36 PM
I use a 100% refined bee’s wax 50/50 with mineral oil mix that I heat up and pour in little jars for customers. It seems to oil and ( kind of ) seal at the same time. I do pretty much like ChefHDAN does on the rest of it.
-- MEL, Kansas
becikeja
#6 posted 05-04-2018 11:49 PM
Thanks for the input. They are end grain boards, I keep them clean and store on the kitchen counter vertical leaning against the wall. They look a little dry, so I will simply add the wax/oil mix again.
Not sure where the skylight inn is mentioned above, but anyone that uses it to cut bbq is ok by me.
View hairy's profile
hairy
3004 posts in 4142 days
#7 posted 05-05-2018 12:43 AM
https://www.popularwoodworking.com/techniques/basics/cutting-boards-the-best-finish
There are lots of opinions.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
CRAIGCLICK
#8 posted 05-05-2018 12:59 AM
- becikeja
The Skyloght Inn is in Ayden, NC. Its the home of Eastern NC Barbecue which is a vinegar based whole hog barbecue. It is the original NC BBQ and considered by many to be the original style of pork BBQ.
The other major NC style of BBQ is Lexington style which is pork butts and is a pepper/winegar/ketchup based.
Both are so good you will leave yoir wike and kids on Christmas day for ‘em.
View Woodknack's profile
Woodknack
13025 posts in 2990 days
#9 posted 05-05-2018 02:27 AM
The wood is dead and oil is just for looks, so it doesn’t really matter how you do it as long as you like the result.
View AlaskaGuy's profile
AlaskaGuy
5523 posts in 2919 days
#10 posted 05-06-2018 03:28 AM
The wood is dead and oil is just for looks, so it doesn t really matter how you do it as long as you like the result.
- Woodknack
The goal of board oil is to penetrate the wood and saturate the wood fibers, in order to stop any other liquids (blood, bacteria) and moisture from soaking into the board. As well, a well-oiled cutting board will keep the same shape when the wood fibers are saturated, so it will not expand and shrink compared to a board that is left to completely dry, then exposed to water. This shrinking and expanding effect is the main cause of warped cutting boards.
While board oil penetrates the wood, board cream/wax acts as a physical barrier on the surface of the wood that protects against stains and liquids. The wax also aids in sanitation, as it fills and seals in knife scars and microscopic cracks where bacteria would otherwise gather.
Used in conjunction, cutting board oil and cream provide an effective combination of protective outer layer and sealed wood that is sanitary, easier to clean and won’t warp.
View Mojo1's profile
Mojo1
286 posts in 3300 days
#11 posted 05-10-2018 07:09 PM
I love the way the mineral oil makes the boards look.
