Laguna 1412 fence not square
Forum topic by Fuzzybearz posted 05-03-2018 06:21 AM 989 views 0 times favorited 3 replies Add to Favorites Watch
View Fuzzybearz's profile
Fuzzybearz
104 posts in 671 days
05-03-2018 06:21 AM
Topic tags/keywords: bandsaw saw resaw square wood
I have a laguna 1412 fence which came with the bandsaw. The bottom part of the fence is square so i get the right cuts.
However the top part of the fence is not square and angled slightly away from the blade. When i resaw wood, the bottom is the width I need but it slowly flares out so the bottom of my board will be 1” and the top 1.1” how fo i square the top part?
Could it be my technique? I press my paddle against the middle of the board to get max sueface to aurface contact with the fence. Should I be pushing heavily from the bottom?
Ill post up pics tomorrow
3 replies so far
View Clarkswoodworking's profile
Clarkswoodworking
289 posts in 735 days
#1 posted 05-03-2018 10:26 AM
Table is not level to the blade
You may think it is but trust me your off just that much !
Scott
Fuzzybearz
#2 posted 05-03-2018 03:01 PM
You sir are correct. Thank you i can solve this now.
Scott
- Clarkswoodworking
Scott
- Clarkswoodworking
View Elwyn24601's profile
Elwyn24601
15 posts in 1016 days
#3 posted 05-03-2018 03:12 PM
I had the same issue, Mine was not in regards to the table. If the problem persists, I corrected my issue with a few strips of blue tape as a shim and that brought everything right into square! Hope your resawing goes well!
