How much camber for a foreplane?
« back to Hand Tools forum
Forum topic by bbasiaga posted 05-01-2018 01:05 AM 486 views 0 times favorited 5 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1243 posts in 2606 days
05-01-2018 01:05 AM
I just got a Sargent 418, which is equivalent to a Stanley no 6. Dated to 1942, so it has some war time features, such as no brass. I plan to use it as a rough work plane and want to put a decent camber on the blade. How much? I have a little scrub plane that I made from a HF no 33, and I think i put an 8” radius on that one. Same for this? Too aggressive for this wider blade?
Looking for your opinions.
Thanks,
Brian
5 replies so far
View JayT's profile
JayT
6364 posts in 2822 days
#1 posted 05-01-2018 01:11 AM
I use an 8in radius on my 5-1/2 and it works just fine.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View bondogaposis's profile
bondogaposis
5613 posts in 2962 days
#2 posted 05-01-2018 01:27 AM
8 or 10” radius is about right. Since you already have and 8” radius on your scrub, try a 10” radius on the 6.
-- Bondo Gaposis
bbasiaga
#3 posted 05-02-2018 06:15 PM
Thanks guys! I will give 10” a shot.
Just gotta make a template with something.
Brian
View bandit571's profile
bandit571
24440 posts in 3295 days
#4 posted 05-02-2018 06:49 PM
Might try just the corners? And barely camber the middle….unless you like planing away a lot of scallops caused by that camber.
bbasiaga
#5 posted 05-02-2018 11:10 PM
Bandit,
Fast stock removal is the goal here. I have a 5 1/2 and a 7 sharpened as you suggest for tasks where I want a better surface immediately off the plane.
Brian
