Problem connecting 4in hose to 4in dust port
Forum topic by RedWoodworker posted 04-30-2018 02:24 PM 473 views 0 times favorited 8 replies Add to Favorites Watch
View RedWoodworker's profile
RedWoodworker
34 posts in 798 days
04-30-2018 02:24 PM
I recently bought a Jet DC-650 dust collector, which has a 4 inch port. I went to Woodcraft and bought a 4inch diameter hose and clamps. The problem is, the hose will not fit around the port. It is exactly the same size and I can’t seem to get it over the port (especially since the Jet DC-650 adapter has screws sticking out on the size of the port).
I’m sure there is a simple solution I’m just not thinking of, but I would appreciate any advice. Thanks!
8 replies so far
View Andre's profile
Andre
3021 posts in 2417 days
#1 posted 04-30-2018 02:42 PM
4 inch inside diameter “ID” or 4 inch outside diameter “OD”? Welcome to the pipe, tubing, hose diameter fitting game!
Plus all fittings really not manufactured to exact standards usually! Best to find one system, supplier and stick with it.
View jmartel's profile
jmartel
8703 posts in 2762 days
#2 posted 04-30-2018 02:45 PM
5932 posts in 3105 days
#3 posted 04-30-2018 02:45 PM
Don’t expect anything in DC to fit anything else. However. of your 4” hose doesn’t have a wire core around it you might e able to warm it up with a heat gun and stretch it over the port.
View Loren's profile
10477 posts in 4259 days
#4 posted 04-30-2018 03:40 PM
Sometimes you can stick a piece of 4” pvc
drainage pipe inside the outlet and work
the hose over the other end.
RedWoodworker
#5 posted 04-30-2018 03:48 PM
- Andre
Sigh. Nothing can ever be easy :)
I think I will try the Woodcraft fitter posted by jmartel. Thanks everyone!
View jonah's profile
jonah
2092 posts in 3910 days
#6 posted 04-30-2018 04:30 PM
It’s a given that anything you buy for the purposes of dust collection will not fit with anything else.
I can’t figure out why dust collection fittings, pipe, and tubing are all weird in between sizes. Plumbing doesn’t work this way. There’s a fitting size and a pipe/street size in plumbing. Why can’t dust collection work like that?
View WhyMe's profile
WhyMe
1209 posts in 2172 days
#7 posted 04-30-2018 05:37 PM
If you are talking about the clear type hose, my experience is the hose needs to be heated to expand or be flexible enough to stretch over the port. I have a couple of those quick connect hose connectors linked above and don’t like them, they just don’t stay on tight to the port on my equipment. The tapered end just doesn’t fit real tight to the port.
RedWoodworker
#8 posted 04-30-2018 05:40 PM
If you are talking about the clear type hose, my experience is the hose needs to be heated to expand or be flexible enough to stretch over the port. I have a couple of those quick connect hose connectors linked above and don t like them, they just don t stay on tight to the port on my equipment. The tapered end just doesn t fit real tight to the port.
- WhyMe
I bought the following hose at Woodcraft:
https://www.woodcraft.com/products/4-diameter-clear-dust-collection-hose
It has metal rings, but I will try to heat it up with a hair dryer and see if it works. Thanks for the tip.
