Brass Rod Hinge
Forum topic by Quailguy posted 04-29-2018 06:06 PM 421 views 0 times favorited 3 replies Add to Favorites Watch
View Quailguy's profile
Quailguy
63 posts in 1803 days
04-29-2018 06:06 PM
I am building a small (11×5x4) curly maple box with mitered corners. I want to use a 3/32” brass rod as a hinge. In my head, I see the lid sitting on a rabbet around the inside of the box with a tab to lift it. Here are my questions: If the rabbet is the same depth all around, will the lid be able to rotate up? How do I determine the distance from the back/inside box edge to position the rod? Do I need to modify either the rabbet or the lid to make it work? I tried drawing it in Sketchup, but didn’t help as much as I am sure you folks can.
Thanks in advance
Quailguy
3 replies so far
View shipwright's profile
shipwright
8453 posts in 3409 days
#1 posted 04-30-2018 12:03 AM
This may be what you are looking for. http://lumberjocks.com/shipwright/blog/series/4096
...or not …
runswithscissors
3081 posts in 2637 days
#2 posted 04-30-2018 01:16 AM
Often, when I’m puzzled about how the geometry is going to work on a project, I’ll make a mockup out of cardboard or other light material so I can test out the design. Manila file folder material is good, also thin foam board if you want a little stiffness. I use pins, paper rivets (not sure of the right nomenclature here) or anything handy for pivots. Though a bit crude, it lets me know whether I’m on the right track, or have to rethink my approach.
Quailguy
#3 posted 04-30-2018 03:00 PM
Good ideas! I’ll tackle that today.
Thank you
