Delta T3 fence install help
Forum topic by LucasWoods posted 04-29-2018 12:41 AM 476 views 0 times favorited 8 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
448 posts in 1938 days
04-29-2018 12:41 AM
I have a Grizzly G1023 table saw and got a much needed fence for it. I need some help or suggestions on how to drill new holes and lay them out right.
I am thinking that the new holes will be drilled at the same level as the old ones in the rails. I haven’t ever laid out drill holes before and don’t know the best way to make sure the front and back rails all line up right.
I have a drill press, HSS bits and countersink bits.
-- Colorado Springs, CO - USAF
8 replies so far
LucasWoods
#1 posted 04-29-2018 02:14 PM
Bump
View jonah's profile
jonah
2092 posts in 3904 days
#2 posted 04-30-2018 11:15 AM
Clamp the rails securely to the table and extensions, then drill directly through the existing holes in the rails through the cast iron. Cast iron is a lot easier to drill than steel. You’ll want a quality, sharp drill bit suitable for metal drilling. You could use a bit of cutting fluid, but it’s not strictly required.
View Gentile's profile
Gentile
357 posts in 2424 days
#3 posted 04-30-2018 03:50 PM
Years ago I put a Steel City fence on my Unisaw. Fortunately, I only had to drill one hole and thread it. It went well. Cast iron is easy to drill and tap. I like what Jonah suggested…
-- "I cut it twice and it's still too short"
LucasWoods
#4 posted 05-01-2018 04:38 AM
Do I need to tap it? It seems all the bolts that came with the rails are long enough to pertrude through the top and then be secured with a washer and nut. Same thing with the wings.
And yes that does seem much much easier. I have not drilled through metal much and thought the thinner rails would be easier.
Did you all just use a hand drill and a HSS drill bit?
jonah
#5 posted 05-01-2018 01:51 PM
Provided there is clearance on the back side of the table/wings to get a washer and nut on there, then you won’t need to tap the holes, no.
A corded drill and a quality HSS or cobalt drill bit is the ticket. In a pinch, a cordless drill will work, but they don’t tend to have the speed or torque of corded ones.
Individual cobalt bits aren’t too expensive (figure $5-8 or so) and should last a good long time. If you’re at a store buying a drill bit, it wouldn’t hurt to get a bit of cutting fluid – it’ll make your drill bits stay sharper longer by keeping them cool.
View TheFridge's profile
TheFridge
10859 posts in 2091 days
#6 posted 05-01-2018 02:17 PM
All the the fences I’ve seen had countersunk hardware so the fence didn’t hit it while sliding.
You can bolt it and use nuts.
View dday's profile
dday
172 posts in 2035 days
#7 posted 05-01-2018 04:36 PM
I used a corded drill and HSS bit to drill holes in my rail to add an extension wing to my TS.
Cordless just couldn’t do it.. the corded drill was like butter…
LucasWoods
#8 posted 05-01-2018 05:46 PM
I do have a corded drill that is from the 50’s probably. It is all metal. I will have to plug it in and see if it works.
