Recomendations/Pictures Needed of Multi Track or other installed router fences for Shop Fox Classic
Forum topic by BoilerUp21 posted 04-27-2018 01:08 PM 3828 views 0 times favorited 3 replies Add to Favorites Watch
View BoilerUp21's profile
BoilerUp21
149 posts in 1379 days
04-27-2018 01:08 PM
I have done a little searching, but can’t decide on what brand/type of multi track fence to install on the right side of my new Grizzly table saw with router wing. I am looking for something relatively low cost, but more durable than attaching MDF. I know Rockler sells 36” sections of 3” multi fence, but I don’t want to cut it and want to be able to attach a dust collection hose…
Does anyone have recommendations for existing full setups or multi track sections that they have installed? I will be using a couple stop blocks and feather boards for small production work.
Thanks!
3 replies so far
View CaptainKlutz's profile (online now)
CaptainKlutz
2282 posts in 2106 days
#1 posted 04-28-2018 10:12 AM
Hmm..
Requirement to have dust collection from top means you need to add some type of spacer between existing saw fence and actual router fence. This is primary reason I choose to use a separate fence for my saw router extension table.
One solution for dust collection with saw fence is to create a 3-5” sq u-shaped channel from BB plywood that attaches to saw fence, plus has a boxed in area behind the router bit to collect debris via hose. Then mount what ever type of front router fence face you desire. Use of Rockler extrusion, or even 80/20 extrusion opens a world of options. Another DIY option is create a modified version of Ultimate Router Table fence.
If you want more options for pre-made fence components, PeachTree offers all their fence components separately, so you can create a fence your choice. If nothing else, the parts list helps you design your version of ultimate router fence. I use the Uni-T-Fence sections on my router table to help create zero clearance fence for profile bits.
Best Luck.
CaptainKlutz
#2 posted 04-28-2018 03:45 PM
BTW – This project was posted today showing prefect example of fence I attempted to describe above:
http://lumberjocks.com/projects/376017
BoilerUp21
#3 posted 04-28-2018 04:07 PM
- CaptainKlutz
Awesome, thanks for your responses!
