Mortising Machine...Worth it?
Forum topic by CRAIGCLICK posted 04-18-2018 04:16 PM 958 views 0 times favorited 10 replies Add to Favorites Watch
View CRAIGCLICK's profile
CRAIGCLICK
117 posts in 685 days
04-18-2018 04:16 PM
Hi All
I have a line on a Jet JBM-5 benchtop mortising machine that is being sold for reasonable coin with various size chisels. I think I can pick it up for 200 bucks. Is that a decent deal?
I definitely want to get deeper into joinery.
-- Somewhere between raising hell and amazing grace.
10 replies so far
View PPK's profile
PPK
1645 posts in 1421 days
#1 posted 04-18-2018 04:54 PM
A motising machine is DEFINITELY worth it. Unless, of course you’re wanting to spend huge money on a domino machine or you’re the “hand-tool-only” type of guy.
I personally own the machine you reference, and it’s a very decent machine. I think $200 may be a little steep, but close to the rance for used. I suppose it depends on how MUCH it’s used. I think they go for $350 new. I’d pay $150 for it used in a heartbeat.
-- Pete
View edapp's profile
edapp
332 posts in 2041 days
#2 posted 04-18-2018 06:40 PM
I picked up a powermatic bench top mortiser or craigslist last year. I have only used it for one project, but now that I have, i will be planning on using it more in the future. I really enjoyed it! I have many craftsman style pieces in my “to do” list that include through tenons, and like I said this thing really works well and leave a clean cut. Definitely a one trick pony, and for that reason i do not keep in my shop, but when you need it it does the job very quickly.
View Rich's profile
Rich
5157 posts in 1201 days
#3 posted 04-18-2018 08:29 PM
I have that mortiser too. I turned it 180º on the base in order to increase its capacity for my residential door stiles that are up to 6” wide.
CRAIGCLICK
#4 posted 04-18-2018 08:54 PM
- Rich
I was wondering…It looked like the most you could fit in it was 4 3/4 inches, which wasn’t enough for my needs. Thanks for the workaround.
View Rich's profile
Rich
#5 posted 04-18-2018 09:16 PM
I was wondering…It looked like the most you could fit in it was 4 3/4 inches, which wasn t enough for my needs. Thanks for the workaround.
- CRAIGCLICK
One thing to be cautious about is the strength of the metal that the post that the hold-down attaches to sits in. It doesn’t go very deep into the base metal, and that metal is kind of weak. Drilling 2 1/2” deep mortises and relying on the hold-down to keep the board in place was too much for it and the metal cracked. I wound up bedding it in a deep well of epoxy and it’s held just fine since then. Mine is about 20 years old, so it’s possible they’ve addressed this weakness since then.
Still however, I don’t just raise the handle and let the hold-down take the full force of extracting the chisel (which gets pretty intense plunged deep into very hard wood), I hold it down with my hand, and I also use a pattern of starting with maybe a 1/2” deep plunge, then move the board over three-quarters of the width of the chisel and go 1”, then come back and go deeper on the first one and so forth. That prevents the chisel from being embedded in a tight deep single-width mortise with all that friction. Remember too, when you make a single deep plunge like that, the wood fibers all are bending downward around the chisel and holding it even tighter — the same way wood holds a nail tight.
View verdesardog's profile
verdesardog
171 posts in 3223 days
#6 posted 04-19-2018 12:29 PM
A mortiser is nice to have if you need it… LOL since I don’t do many I have one of those kits that fits on a drill press . It’s a pita to use but works.
-- .. heyoka ..
View LesB's profile
LesB
2320 posts in 4054 days
#7 posted 04-19-2018 04:53 PM
If you have extra funds and want to invest in a more versatile machine that does both mortises & tenons in one setup plus, dove tails, box joints and other things in one tool take a look at this at: hybridpantorouter.com
I recently got one and I’m very impressed with it. I posted a review on this a few weeks ago.
-- Les B, Oregon
View pintodeluxe's profile
pintodeluxe
6040 posts in 3425 days
#8 posted 04-19-2018 05:32 PM
It’s a must have tool for me. In fact I have two – one is a Delta benchtop unit, and the other a Jet floor model. The benchtop models do have some limitations both in the size chisels they accept and the width of board you can mortise. I only found that a limitation for making doors, where the bottom rail can be up to 10” wide.
I will say the floor mortiser requires a lot less effort, but the benchtop model is a good place to start.
I say go for it.
CRAIGCLICK
#9 posted 04-19-2018 06:32 PM
I recently got one and I m very impressed with it. I posted a review on this a few weeks ago.
- LesB
Unfortunately, extra funds are pretty limited. That is a beautiful setup, though. Maybe someday!
View Andre's profile
Andre
3021 posts in 2417 days
#10 posted 04-19-2018 08:07 PM
A mortiser is nice to have if you need it… LOL since I don t do many I have one of those kits that fits on a drill press . It s a pita to use but works.
- verdesardog
LOL! Me too, works okay especially on my 17” General DP but usually quicker to chop them out by hand?
Maybe on day I will find a good used machine fo a reasonable price?
