Hinge help
Forum topic by notmyrealuser posted 04-17-2018 02:18 PM 391 views 0 times favorited 5 replies Add to Favorites Watch
View notmyrealuser's profile
notmyrealuser
3 posts in 643 days
04-17-2018 02:18 PM
New to the site, but have lurked for a while. I’m just getting into woodworking and went pretty big with my first project – all new kitchen cabinets! So far I am happy and am learning a lot. I have a degree in Industrial Engineering and Design and designed them all on CAD.
I need some help with the correct hinge for a corner upper cabinet that’s face is at 45 degrees. Its a full inset door with frame-less case. The sides on the door and on the case where the door fits are beveled at 22.5 degrees. When the door is closed you cannot see the case of the corner cabinet, but you can see the 18mm case of the neighboring cabinet. This is so I don’t end up with 36 mm thickness on either side of the corner cabinet and they match the rest. Do I need blind corner hinges for this or is there something else I should look at?
Thanks in advance everyone!!!
5 replies so far
View DS's profile
DS
3359 posts in 3024 days
#1 posted 04-17-2018 02:26 PM
Probably you will need some variation of the guy in the center there…
notmyrealuser
3 posts in 643 days
#2 posted 04-17-2018 03:46 PM
Thanks DS, that looks like what I need. I can’t read the part number on the jpg, do you have a link to that pdf?
notmyrealuser
3 posts in 643 days
#3 posted 04-17-2018 03:53 PM
Nevermind, I found it. Looks like they specifically make ‘Mitered corner’ hinges.
I found this planning guide on the Blum website that may help others:
https://d1.blum.com/BEC003/cliptopbmnah2016_pt_dok_bus_$sus_$aof_$v1.xlsm
View DS's profile
DS
#4 posted 04-17-2018 03:59 PM
Yep, now you are cooking with gas…
Good Luck!
View ChefHDAN's profile
ChefHDAN
1496 posts in 3453 days
#5 posted 04-17-2018 05:01 PM
Always trust Blum !!!
