Blast gate finish
Forum topic by RobHannon posted 04-13-2018 03:59 PM 336 views 0 times favorited 2 replies Add to Favorites Watch
View RobHannon's profile
RobHannon
326 posts in 1135 days
04-13-2018 03:59 PM
I am building some 6” blast gates out of MDF because I have it. I was thinking of just giving them a good coating of past wax to seal them a but and keep them moving well. My other thoughts are shellac or BLO. Any opinions on what would work out the best?
2 replies so far
View Lazyman's profile
Lazyman
4495 posts in 1991 days
#1 posted 04-13-2018 04:31 PM
I would think that the paste wax might need to be refreshed from time to time so I would put a light coat of water based poly on them first. Poly is fairly slick to begin with and will reduce the chances of humidity causing the MDF to expand a bit. A light coat of wax after the poly will make them slide even better. Just size the slot they’ll ride in after applying the poly.
View bonesbr549's profile
bonesbr549
1586 posts in 3671 days
#2 posted 04-13-2018 06:34 PM
use what ya got. I would use lacquer. Just because it goes on fast, and dries quick and can whip out 4/5 coats quick then wax and go on.
