eccentric (off center) turning on wood lathe
« back to Woodturning forum
Forum topic by BlasterStumps posted 04-11-2018 04:44 PM 837 views 1 time favorited 4 replies Add to Favorites Watch
View BlasterStumps's profile
BlasterStumps
1494 posts in 1044 days
04-11-2018 04:44 PM
Question for you lathe guys: What should I know about turning in general if I was to attempt to turn a hammer handle? I have a little 10 Oz machinist ball pein hammer that I cleaned up but need a new handle for. It looks like the entire handle should be oval shaped, even the part that enters the hammer head. I haven’t turned much on my old Shopsmith lathe let alone anything off center. Do I need a special drive center to hold the stock properly/safely? Any other ‘must know’ things?
Mike
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View waho6o9's profile
waho6o9
8812 posts in 3181 days
#1 posted 04-11-2018 05:12 PM
Easy peasy face shield is a must.
Practice on scraps first is a good idea. Mark your centerline and then off set a center point a little in each
direction on the same axis and you’re good to go.
https://www.youtube.com/watch?v=9CbRnpYPols
View HokieKen's profile
HokieKen
11992 posts in 1743 days
#2 posted 04-11-2018 05:16 PM
Yep, what Wahoo said^.
I do multi-axis turning for screwdriver handles a lot and I’ve done hammer handles that way. But, to be honest, I find hammer handles come out better and take less time if I cut the rough shape with the bandsaw then finish shaping it with rasps and spokeshaves.
-- Kenny, SW VA, Go Hokies!!!
View hairy's profile
hairy
3004 posts in 4136 days
#3 posted 04-11-2018 05:57 PM
Here’s another way.
https://www.tpt.org/the-woodwrights-shop/video/the-woodwrights-shop-offset-turning/
I made a little hammer handle without offsetting. I started with a rectangular blank, not square. I left it rectangular at the back end and round where it goes in the head. http://lumberjocks.com/projects/50193
If your hammer head is tapered inside, turn it round to the widest diameter, then taper it with a file.
-- Genghis Khan and his brother Don, couldn't keep on keeping on...
BlasterStumps
#4 posted 04-11-2018 09:24 PM
“hairy”, that is actually quite a cool little hammer you made there. I like the looks of it. I have a chunk of brass that I might try to make something similar with. I will try the handle idea. Thanks for sharing the info.
