Marking Tools for Joinery - Wheel, Dual, etc. Which one to get?
« back to Joinery forum
Forum topic by PatrickIrish posted 04-09-2018 03:50 PM 907 views 0 times favorited 13 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
153 posts in 2656 days
04-09-2018 03:50 PM
To improve my accuracy on some work I want to upgrade to better marking and measuring tools.
I was going to buy a rockler brass cutting/marking wheel for $16 but then saw the Veritas $50 dual wheel that makes mortise and tenon measuring a snap. I think they missed the boat by not adding a graduated scale on the bar though.
I got confused when I came across the wheel marking tool then the wood versions with the pin and terminology of marking vs cutting vs layout.
Any suggestions I should look at?
13 replies so far
View jonah's profile
jonah
2092 posts in 3909 days
#1 posted 04-09-2018 04:00 PM
I’ve never had a problem with the Crown wood version I have. It has the pin. I use it infrequently, sometimes using a marking knife instead if the piece is particularly small or narrow.
View BlasterStumps's profile
BlasterStumps
1499 posts in 1050 days
#2 posted 04-09-2018 04:06 PM
If I was in the market for a gauge with pretty much all the bells and whistles and I had the money, I would look close at the Veritas. Nice tool.
I say all that but for me and my mad money budget, I had to resort to making my own. Not the best quality, I can assure you. : )
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Kazooman's profile
Kazooman
1413 posts in 2563 days
#3 posted 04-09-2018 04:34 PM
I recently purchased a Jessem Woodsabre after reading a review on LumberJocks. Not cheap, but extremely well built, easy to adjust, and dead-on accurate.
View EarlS's profile
EarlS
3434 posts in 2959 days
#4 posted 04-09-2018 05:05 PM
I just use a square and pencil to make the initial mark, then switch to a knife to score it along the blade of the square. My reasoning is that I would have to use the square to set up the marking/cutting gauge anyway so why not just use the square and eliminate an additional tool and step?
Is there something inherently better about using a cutting/marking gauge vs. using a square and pencil or knife?
View Rich's profile
Rich
5156 posts in 1200 days
#5 posted 04-09-2018 05:08 PM
I wrote that review for the JessEm. I still think it’s an excellent gauge. Since you mentioned wanting a graduated scale, the JessEm really shines with markings down to 1/256”.
I also have the Veritas 3 in 1 gauge for smaller work. I really like the way it can hold a segment from a 9mm blade. It not only makes a clean mark, but I use it to trim things. When I add adhesive backed felt to the bottom of a box, it’s perfect for trimming the perimeter and leaving about 1/8” reveal so the felt doesn’t show around the edge.
View TheFridge's profile
TheFridge
10859 posts in 2097 days
#6 posted 04-09-2018 05:26 PM
The dual is nice. It’s my go to. I wouldn’t use the measurements on it even if it had it because almost markings are arbitrary anyway.
View Loren's profile
10477 posts in 4259 days
#7 posted 04-09-2018 05:42 PM
I use a Japanese one with a knife. It can be used
as a cutting gauge for thin stock as well.
#8 posted 04-09-2018 05:51 PM
- EarlS
I marked line you can put a chisel in. I use a
pencil a lot but it’s challenging to parse the width
of the lead to get the line exactly where I want it
every time. Mechanical pencils are better but
the line is still offset from the end of the tool.
I use a Veritas sliding square a lot. It has a diamond
shaped cutout at 1” in a pencil tip can be registered
in. I think this approach is more accurate and
consistent than running a pencil against the edge
of a square. I also have one of those Woodpecker
squares with .5mm holes every millimeter. Incra
makes them too.
View Smirak's profile
Smirak
101 posts in 1129 days
#9 posted 04-09-2018 06:57 PM
I like wheel style marking gauges. I like one that I’m able to rest the face on a pc of material, release the screw and when it bottoms out, I know I’ve got the thickness of what I’m trying to measure. Does the Jessem have the ability to allow the rod to “float free”?
Thanks,
KS
View Woodknack's profile
Woodknack
13026 posts in 2991 days
#10 posted 04-09-2018 07:21 PM
I have several with pins, one with a blade; the blade is superior. Pins tear the grain when going across and follow the grain when going with. A heavier pin is better, and better yet if you sharpen it into a spear point. I’ve never owned a wheel type.
View Rich's profile
Rich
#11 posted 04-09-2018 07:37 PM
I like wheel style marking gauges. I like one that I m able to rest the face on a pc of material, release the screw and when it bottoms out, I know I ve got the thickness of what I m trying to measure. Does the Jessem have the ability to allow the rod to “float free”?
Thanks,
KS
- Smirak
Yes. You can dial in a precise value, or use it like you describe in your post. It won’t just drop though, you’ll need to push it.
View Derek Cohen's profile
Derek Cohen
482 posts in 4579 days
#12 posted 05-08-2018 04:21 PM
Wheel gauges enable you to transfer an exact thickness … easily …
This is also done with a Japanese cutting gauge I made …
This can only be done with gauges where the blade/cutter is flush with the fence.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
View NeophyteGrant's profile
NeophyteGrant
121 posts in 1120 days
#13 posted 05-08-2018 08:22 PM
JessEm is really solidly machined, and I like the square reference face better than wheels. It will last forever. It’s a wheel and you can hone it.
It does shine at being able to micro-adjust with graduated wheel down to 1/256. It’s amazing but also kind of overkill. It has positive detentes at 1/2” increments, pop out to you get to the nearest 1/2” under where you want to be, then you rotate a micro adjust to advance it between the stop and the next 1/2 inch. This can get time consuming, as if you measure by relative thickness of another piece or a piece of stock you have on hand rather than an absolute number in your head, it takes a while to click it out through the stops, then turn the microadjust wheel a bunch of times to get from 2inches to 2 3/8, say. You can’t just slide the bar freely and lock it.
Other than that, the thing is gold.
