splines on the face of a frame
« back to Joinery forum
Forum topic by stripit posted 04-09-2018 02:41 PM 744 views 0 times favorited 4 replies Add to Favorites Watch
View stripit's profile
stripit
61 posts in 2644 days
04-09-2018 02:41 PM
Topic tags/keywords: jig question
Hi. You folks have helped me out many times be fore. I’m hoping you can do it again. I’m making 8 frames for award certificates, for volenteers . I normally put splines on the edge in the corners, These frames have a beaded edge,and spline would be hard to put in. I want to put a spline across the miter joint on the face of the frame.
I’m thinking of a jig on the miter gauge, to cut a slot 90 degs. to the miter cut. Anyone out there done this before, and how did you do it.
Thanks Joel
-- Joel, People ask what I make. I tell them I make sawdust, and now and then a nice box or frame,or clock, or lamp pops out.
View builtinbkyn's profile
builtinbkyn
2999 posts in 1541 days
#1 posted 04-09-2018 02:49 PM
I don’t see any reason why it can’t be done. A simple 45 degree stop block on your sled or miter gauge should do it. The only issue is accurately matching the size of the spline to the size of the kerf you cut in both mating pieces of a corner.
-- Bill, Yo!......in Brooklyn & Steel City :)
View Ripper70's profile
Ripper70
1368 posts in 1509 days
#2 posted 04-09-2018 02:51 PM
Here’s an example by a fellow LJ’er. A variation Wood Magazine example can be found here.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View LesB's profile
LesB
2297 posts in 4044 days
#3 posted 04-09-2018 05:10 PM
If the frames are wide enough you could put a “butterfly” type inlay across the joint on the back side. I used this on a the back side of a segmented clock bezel (think school clock) using a router inlay kit. The kind with a router template guide that has a removable spacer ring so you can cut both the recess and the inlay with the same template. I made my own template making the wings of the butterfly by drilling overlapping circles in 1/4” masonite with a Forstner bit of the appropriate size.
-- Les B, Oregon
View Bishop78's profile
Bishop78
14 posts in 616 days
#4 posted 05-11-2018 10:32 PM
Bisquits? If the dimensions allow it. Or splines or loose tennons.
If you warterdown your glue and wet the mitres, give the wood time to suck glue up. Leave it to dry then glue the frames up that way the glue won´t be sucked up, the primary reason why the joint isn´t so strong. a 45° edge is only borderline endgrain. Its going to be strong enough for a frame
