Problem with router
Forum topic by mac1964 posted 04-09-2018 01:08 PM 421 views 0 times favorited 4 replies Add to Favorites Watch
View mac1964's profile
mac1964
1 post in 663 days
04-09-2018 01:08 PM
I have a 3.5 hp. Craftsman router that I bought in 1967. The router has a 1/2” and a 1/4 collet. The 1/2” collet has been on the router for several years, I tried to remove the screw so I can take out the 1/2” collet, it will not move. Is the an adapter or sleve I can put in there so I can use a 1/4” router bit.
-- Marcos , South Texas
View HerbC's profile
HerbC
1801 posts in 3461 days
#1 posted 04-09-2018 01:19 PM
I’ve used this one Whiteside…
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View John Smith's profile
John Smith
2128 posts in 764 days
#2 posted 04-09-2018 02:08 PM
I just went through this same issue with my old Ryobi.
during the twisting and turning episodes, the whole chuck came unscrewed.
which was a good thing, this allowed me to put it in the vice and apply heat
with some penetrating fluid and tap tap tap tap with an assortment of tools.
if you can get some kind of bolt with a hook that will grab the bottom of the collet,
you may be able to winch it out with nuts and washers.
if you can get the chuck off, it will help tremendously so you can push from the bottom.
-- I am a painter. That's what I do. I paint things --
View pintodeluxe's profile
pintodeluxe
6032 posts in 3415 days
#3 posted 04-09-2018 03:04 PM
I wouldn’t use a reducer sleeve for normal routing operations. Even if one is available, I don’t trust reducer sleeves as they tend to let bits slip. When bits slip bad things happen.
And am I the only one thinking it… How are you still using a router from 1967???
Collets have changed (gotten much better) in the last 51 years.
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#4 posted 04-09-2018 03:15 PM
- John Smith
DITTO ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ :<))
